how-to: ECU-based direct boost control
Old Sep 26, 2007 | 07:37 AM
  #106
mrfred's Avatar
I currently have 5 JDM MAP sensors available...
Old Sep 26, 2007 | 09:49 AM
  #107
dudical26's Avatar
I can't wait to get mine and try it out!!
Old Sep 26, 2007 | 10:10 AM
  #108
mrfred's Avatar
Yours should be arriving by Friday at the latest.
Old Sep 26, 2007 | 10:15 AM
  #109
dudical26's Avatar
sweet, thanks.
Old Sep 26, 2007 | 10:21 AM
  #110
MR Turco's Avatar
Anxiously checking the mail everyday!
Old Sep 26, 2007 | 10:45 AM
  #111
mplspilot's Avatar
^ same here
Old Sep 26, 2007 | 11:54 AM
  #112
Mr. Evo IX's Avatar
I would like to buy one of the jdm maps if you have any left.
Old Sep 26, 2007 | 12:04 PM
  #113
mrfred's Avatar
PM'ed you... :-)
Old Sep 27, 2007 | 10:33 PM
  #114
Evo_Jay's Avatar
my boost error is wrong. ill have 22.0psi @ 3500 in my map. the car hits 24.xpsi @ 3500 and the boost error only says its +.998 off target boost. this happens in various areas. also it seems like the ecu is following the incorrect boost error readings. any ideas?
Old Sep 28, 2007 | 04:29 AM
  #115
recompile's Avatar
Two things....
First, are you sure EvoScan is logging accurately? Turn the key on but leave the engine off, start logging. JDMMAP should show very close to 0, as in 0.0xxx
If not, fix your EvoScan XML (refer to the JDM MAP instruction thread)
Secondly, is your Boost Adder set to the same value as your EvoScan XML ? For example, if you have to use 14.7 in EvoScan to log 0.0xx boost with engine off, then your Boost Adder should also be 14.7.
Old Sep 28, 2007 | 09:03 PM
  #116
mrfred's Avatar
I've been getting quite a few questions on how to tune the direct boost control system so in the third post in this thread, I've added a detailed description of how to the direct boost control system works and how to effectively tune it. Hopefully, that will answer most people's questions.
Old Sep 30, 2007 | 08:19 AM
  #117
gear head's Avatar
Originally Posted by nj1266
Can anyone translate these formulas into language that Logworks can understand?
<DataListItem DataLog="Y" Color="" Display="Boost Error" LogReference="BoostError" RequestID="8A" Eval="0.0241*x-3.087" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-5" GaugeMax="5" ChartMin="-5" ChartMax="5" ScalingFactor="1" Notes=""/>
<DataListItem DataLog="Y" Color="" Display="WGDC Correction" LogReference="WGDCCorr" RequestID="8B" Eval="0.5*x-64" Unit="WGDC%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-50" GaugeMax="50" ChartMin="-50" ChartMax="50" ScalingFactor="1" Notes=""/>
+1...Has anybody accomplished this?
Old Oct 2, 2007 | 03:47 PM
  #118
Evo_Jay's Avatar
mrfred,
Why did you set-up the range on the BEC table from 3.1 to -3.1? Why not use the stock range? Just curious
When I modified the xml file, I noticed that the TBEC table (the one that I use for load based boost) also changed its range. I had to make two xml files/base files and swap them around to get around this issue.
I made a .xml file (US IX vers. 15) that is very organized and has all the load based tables and all the psi based tables in their own categories. Also has 2 byte rpm and load, all the MAP sensor tables, lean spool table, etc.
PM me for it
Old Oct 2, 2007 | 05:52 PM
  #119
dudical26's Avatar
I have been tunning my boost and I am having some trouble. I turned off correction and set BWGDC in 3rd gear and got the boost to a pretty good point. Then I turned back on correction but here is my problem.
Boost in 1st and 2nd are to low. Boost in 5th is way to high.
I have done a bunch of logs, and taken some screen shots of the troubled areas, then I wrote on each image saying what I think is the issue in that log. If you guys could please take a look at these few pulls and see what you can suggest.
Thanks
http://www.skidmore.edu/~a_blaker/Logs/JDM/
Old Oct 2, 2007 | 06:34 PM
  #120
mrfred's Avatar
I tried to look at the logs, but the files were pretty hard to get good info. From your tables, it appears that the target boost is about 24.5 psi, but with the correction disabled, you're only hitting at best 23.5 psi. If that's correct, then you'll dial in the BWGDC table better than that (+/- 0.5 psi across the rpm range) in third gear with the correction disabled. It can take a while to dial-in the BWGDC table. I spent a few days on mine.
You'll never hit the target boost in 1st gear. Things happen too fast. It should be possible to get close in 2nd gear. 3rd thru 5th (6th) should all be pretty much the same boost across the rpm range.
Can you post a log for the run in 3rd gear with correction disabled?
