how-to: ECU-based direct boost control
Old Feb 11, 2008 | 09:28 PM
  #256
RazorLab's Avatar
Yea that's right so we where both basically wrong at first... haha
anyway.... so back to my original point, if someone wants to run more than 24.6 PSI then changing the "boost adder" table to "atmospheric" might confuse them.
Old Feb 11, 2008 | 09:29 PM
  #257
mrfred's Avatar
Originally Posted by tephra
edit - hey mrfred what was your elevation when you measured 30psi?
300 ft. atm is 14.5 psi in my area.
Old Feb 11, 2008 | 09:31 PM
  #258
tephra's Avatar
Correct!
But the reason why you need to increase boost adder is to compensate for the problem of have 24.6 max psi in your boost baseline table (BDEL).
I think we can remove this 24.6 psi limit (and make it 49.2) with some very simple changes; changes that mrfred is already doing (0x4a00 for example).
Anyways not a big deal
MrFred - so basically the JDM 3bar is underspec'd?
Old Feb 11, 2008 | 09:36 PM
  #259
RazorLab's Avatar
Yea i think if you remove the 24.6 limit then changing the boost adder table to "atmospheric" would make more sense.
phew that took alot of posts. haha
Old Feb 11, 2008 | 09:40 PM
  #260
mrfred's Avatar
Seems to be the case. It flatlines at 32 psi.
Old Feb 11, 2008 | 09:44 PM
  #261
tephra's Avatar
yep
sometimes its hard to explain something when you don't have a 100% grasp of it hehe
To add MrFred is entirely correct in saying you will loose that .1 granularity of control by dumping the 2x multiplier.
Old Feb 11, 2008 | 09:49 PM
  #262
RazorLab's Avatar
.1 or .2 is almost the difference pull to pull. I say big deal.
Old Feb 11, 2008 | 09:56 PM
  #263
tephra's Avatar
well MAP sensors are only accurate to like 98% so over 25psi that's .5 of a psi (25*0.02)
So maybe your joking?
Old Feb 11, 2008 | 09:57 PM
  #264
RazorLab's Avatar
Ok that might be an issue...
Old Mar 6, 2008 | 07:29 AM
  #265
MR Turco's Avatar
So the weather is finally getting nice out. I will be playing with the ECU boost control tonight and i wanted to post up what i have so far. This is just a starting point. I have the GM 3-port BCS already wired in. I am really only looking to start at low boost levels and then moving forward need be.
Please any input would be much appreciated.
Mitsulogger definitions:
<Request LogReference="BoostError" RequestID="8A" Eval="0.0241*x-3.087" Unit="psi" Logged="y" Response="1" />
<Request LogReference="WGDCCorr" RequestID="8B" Eval="0.5*x-64" Unit="WGDC%" Logged="y" Response="1" />
Old Mar 6, 2008 | 11:07 AM
  #266
RazorLab's Avatar
looks good, I thinj the -15 at 3.1 will be too much as if it ever hit's that you don't have enough additive correction to bring it back up. However, it will work well as a failsafe.
You can also get rid of the 500-1500 rpm in the psi table and give yourself more resolution in the other rpm points.
Old Mar 6, 2008 | 11:31 AM
  #267
MR Turco's Avatar
Good point, thanks!
Old Mar 6, 2008 | 11:34 AM
  #268
RazorLab's Avatar
Can you also post your WGDC table?
Old Mar 6, 2008 | 11:47 AM
  #269
MR Turco's Avatar
I think this should be conservative enough. Hopefully.
BTW mods on the car are O2 housing, ported exhaust manifold, and megan DP. HFC and drop in filter should be coming soon but I will be staying with the stock catback.
Old Mar 6, 2008 | 11:52 AM
  #270
RazorLab's Avatar
Might be a tad too much duty cycle up top if your target is 16psi.
I would run 50-60 from 5430 up for the first couple datalogs and see what that gets you, then add from there.
