how-to: ECU-based direct boost control
Old Jan 21, 2008 | 09:49 AM
  #181
mrfred's Avatar
Originally Posted by nj1266
I was really disappointed. I just acquired a Vishnu bleeder. It is the same one that mrfred is using. I might try direct boost control with it. mrfred uses it with direct boost and it works.
I think it would be great if you gave it a try with the Vishnu bleeder (and stock pill at the tee and no pill at the BCS side). I don't even look at the boost gauge any more because I know its working. :-)
Old Jan 21, 2008 | 10:05 AM
  #182
FuelsResearch's Avatar
Anyone know the approximate orifice size of the stock T pill? My has been mia for a few years. I may try the vishnu bleeder as well. Is it what they call the passive boost solenoid emulator? Hell, I'll try em all!
Old Jan 21, 2008 | 01:55 PM
  #183
mrfred's Avatar
Yep, that's the passive boost solenoid emulator. If you can find a metal tee, it would be easy enough to fill in the branch with solder, and then drill a hole to make a bleeder.
Old Jan 31, 2008 | 06:39 AM
  #184
MR Turco's Avatar
Can people who are running a GM 3-port BCS post up their BEC and BWGDC tables. I am looking to see how people with the 3-port are setting them up.
Old Jan 31, 2008 | 07:37 AM
  #185
laramie_05MR's Avatar
+1 I bought the 3 port yesterday.
Old Feb 1, 2008 | 09:02 AM
  #186
MR Turco's Avatar
Bump, anyone out there with this?
Old Feb 1, 2008 | 09:53 AM
  #187
TouringBubble's Avatar
Just a note ... I'm doing some testing with a mostly flat BWGDC profile and basically letting the TBEC table control the boost. Results were promising to start, but my car's been down for a week. I'll do some more testing when I get it reassembled.
The only problem I see with it so far is that the stock BCS is a little slow to react and there seems to be a maximum correction that can be applied to the WGDC. I think the GM solenoid and a little more correction delay could help with the response in this situation and the max correction isn't an issue if you set the BWGDC somewhere logical.
Old Feb 1, 2008 | 10:09 AM
  #188
roger smith's Avatar
I use a GM 3-port. Don't know if I should add what I have because i'm not using direct boost control, I'm on load-based. But here is my current WGDC table and the boost curve it produces (this error correction off).
Attached Thumbnails how-to: ECU-based direct boost control-currentmwgdc.jpg   how-to: ECU-based direct boost control-boostprofile.jpg
Old Feb 1, 2008 | 10:45 AM
  #189
MR Turco's Avatar
Very interesting. I would like to see your results when you get them. What sort of BWGDC are you thinking, like 70% across the board?
Old Feb 1, 2008 | 11:23 AM
  #190
I started on 45% I think because of the weather ... that's why I found the correction limit. I wanted to keep it safe for the initial testing. I was running ~65% or so for my desired load.
Choosing a median BWGDC for all seasons would be the key to avoiding the correction limit ... likely somewhere around 70% as you mentioned.
Old Feb 1, 2008 | 12:26 PM
  #191
Evo_Jay's Avatar
If you guys remember I recommended this way of tuning a long time ago.
Old Feb 1, 2008 | 12:29 PM
  #192
Evo_Jay's Avatar
sept. 16, 07
Originally Posted by Evo_Kid
Yeah, defiantly tune like this. Zero TBEC, use WGDC to get you to your desired boost level, then re induce the TBEC.
The only thing I do different is a run a flat WGDC ie 65s from 3000-7000. I just make sure that the WGDC I use, gets me to my desired peak boost. I then let the correction take away the taper.
Old Feb 1, 2008 | 12:30 PM
  #193
Evo_Jay's Avatar
Oh yeah, I found one problem wit this style of tuning, Ill explain more when i have time.....
Old Feb 1, 2008 | 12:59 PM
  #194
MR Turco's Avatar
Wow i never saw your original post, easy to miss on this forum. I will be interested to see what you have found.
Old Feb 1, 2008 | 03:07 PM
  #195
I remember your post, but you never really expanded on it much. That's why I'm trying it out now ...
I'm thinking the problem you found with this method is that TBEC doesn't zero out when you let off the throttle ...
