how-to: ECU-based direct boost control
Old May 7, 2008 | 12:23 PM
  #376
RazorLab's Avatar
Yes, or if you are like me and tune a bunch of different evos every week you can just switch the scaling back and forth on the "Alternate Boost Desired Engine Load" map depending on what type of boost system you are tuning and if you are using alt maps or not.
Old May 7, 2008 | 04:40 PM
  #377
laramie_05MR's Avatar
thanks tephra. hopefully i'll have time this weekend to play with the car and see what i can do with v5
Old May 7, 2008 | 04:47 PM
  #378
tephra's Avatar
no prob's
RL I just created a new catagory - "Direct Boost" and had duplicates of all the tables in there.. so I could see both BDEL (in the Turbo cat) and Target Boost (in the DB cat)...
Old May 7, 2008 | 10:03 PM
  #379
dudical26's Avatar
I think it was discussed once before but only briefly so I would like to again bring up the idea of gear dependent boost control.
The idea was to assign BWGDC #1 to gears 1&2
BWGDC #2 to gears 3&4
BWGDC #3 to gears 5&6
What do you guys think about this idea. I have done a fair bit of tunning with the direct boost control system, and while I have managed to achieve pretty good results I always find that it is a compromise between reaching maximum boost in lower gears and not over-boosting in higher gears.
I know Tehpra is working on a PID boost control system but I don't really know what his goals or methods for the system are going to be, maybe something of this nature can be included. Does anyone have a link to a post where Tephra outlines the goals of the new system?
Old May 8, 2008 | 04:35 AM
  #380
MR Turco's Avatar
I think it is a band-aid. I'd rather have a full PID controller or at least a 3d map with all the tables. It would be quite annoying tuning different gears in different tables.
Old May 8, 2008 | 04:42 AM
  #381
tephra's Avatar
my goals are simple.
a boost control system that doesn't spike (much) and reacts the same in all gears
Old May 8, 2008 | 05:07 AM
  #382
MR Turco's Avatar
i.e. what the car should have came with
Old May 8, 2008 | 06:43 AM
  #383
dudical26's Avatar
Sound like some good goals to me.
I don't know all that much about PID controllers but from what I can gather I believe what we have is a P controller if I'm not mistaken. Is it reasonable to assume that by simply adding I and D values into the equation we can achieve such a boost control system? Forgive me if I'm saying something silly or obvious but I am just trying to understand exactly how you will achieve an accurate boost control system.
From Wikipedia
The PID controller calculation (algorithm) involves three separate parameters; the Proportional, the Integral and Derivative values. The Proportional value determines the reaction to the current error, the Integral determines the reaction based on the sum of recent errors and the Derivative determines the reaction to the rate at which the error has been changing. Some applications may require using only one or two modes to provide the appropriate system control. This is achieved by setting the gain of undesired control outputs to zero. A PID controller will be called a PI, PD, P or I controller in the absence of the respective control actions
Old May 8, 2008 | 06:49 AM
  #384
MR Turco's Avatar
basically we need our boost control to take in more variables. A full 3d map of RPM, WGDC and load or TPS would really help.
Old May 8, 2008 | 06:59 AM
  #385
dudical26's Avatar
Correct me if I am mistaken, but I think that would still be a P controller. You would just be using more inputs in calculating the P value.
Old May 8, 2008 | 07:36 AM
  #386
tephra's Avatar
basically when its done you will have a 2d or 3dmap with RPM on the Y and throttle on the X and target psi/load as the map..
you wont need or be able to specify the wgdc...
I have started the code but havn't had to time to debug it properly..
Old May 8, 2008 | 07:40 AM
  #387
MR Turco's Avatar
nevermind.
Old May 8, 2008 | 09:51 AM
  #388
mrfred's Avatar
Its closer to an I system. The WGDCC is the I value. I do like the idea of a PID system, but I think the OEM system gets a bad rap. It lacks a few features not related to PID control, but otherwise can be made to work very well.
Old May 8, 2008 | 05:00 PM
  #389
racer135's Avatar
Originally Posted by mrfred
Here are the results of a 3rd gear log that I took on my way back from lunch.
Quick question. What happens if you are in third or fourth at 4K RPM with very low boost (light on pedal) and hit it WOT (like in a freeway run) when you overshoot boost by more than 3 you will correct with a -18% WGDC your boost will drop and will never come back because anuthing less than -1.4 is zerod. Is that right? Thats what happening to me with the load based setup on a sudden freeway pull that overshoot boost.
Old May 31, 2008 | 10:23 PM
  #390
fostytou's Avatar
EvoM Community Team
you got it, but on the current system its the best you have got.... otherwise you are overcorrecting way to much on spoolup... you just have to remember not to stab it in 5th unless you want to be stuck under your threashold (~18psi is not so bad IMO)
