suggestions on my Log
Old Sep 10, 2007 | 10:54 AM
Nevonate's Avatar
Here is a 3rd gear log that I did in Evoscan yesturday (20psi). pull starts at 14 sec. Other than small fuel adjustments, everything else is stock. Any suggestions?
-nate
Old Sep 10, 2007 | 11:03 AM
tkklemann's Avatar
First off, post it as a .csv so it is easier for people to read...
Old Sep 10, 2007 | 11:20 AM
Nevonate's Avatar
Can't uplaod a .csv . I'll zip it and load it up.
Old Sep 10, 2007 | 11:23 AM
Nevonate's Avatar
Done. the zip now contains the CSV
Thanks in advance!
-nate
Old Sep 10, 2007 | 11:43 AM
Pd1's Avatar
Pd1
The attached log is pretty useless, honestly.
You've got to at least log KnockSum. You should also try and log TPS, Fuel Trims, Wideband (if you have one) and ideally boost (if you can).
Old Sep 10, 2007 | 12:20 PM
Nevonate's Avatar
I figured as much. I"ll post another one tonight.
Old Sep 10, 2007 | 12:22 PM
joosdawg's Avatar
exacly what i was thinking when i opened it wheres the tps knocksum ect
Old Sep 10, 2007 | 01:07 PM
Nevonate's Avatar
What values am i looknig for in knock sum? how much is too much?
Old Sep 10, 2007 | 01:10 PM
roger smith's Avatar
No one knows what knock counts hurt the engine but I think knock counts of 3 or 4 and above will decrease timing and hurt performance.
For me I'd try to tune to knock-free or random knock counts of 1 or 2.
One thing you can see from your log, I believe, is that your boost spikes to 20 and then drops a lot. What method are you using to control boost? You should setup your boost first as changing boost changes AFR.
Old Sep 10, 2007 | 01:14 PM
TouringBubble's Avatar
I tend to aim for 0 knock, but that's not really possible if you want to make good power. I accept a few 1 counts and the occasional 2 if I have to. When it comes down to it, if you aren't on the verge of a small bit of knock, you are leaving power on the table.
aamoedo
Oct 1, 2016 04:46 PM
nicolassabra
Jan 12, 2014 04:08 AM
elhalisf
Jun 4, 2010 05:28 PM
evo8dad
Jan 31, 2009 03:48 PM
EVOLex
Jul 3, 2008 09:31 PM
