Strange knock issues....VERY STRANGE
Old Sep 12, 2007 | 03:48 AM
wrx_ua's Avatar
Here it is. EDM 05 EVO 8 stock. 99 oct RON. Knock sum goes up to "5" from 3000 to 4500 rpm, then "4" from 4500 to 5000rpm.. and end up with 1-2 at 7000 on STOCK MAP. I've loaded Ecutek map already tried on EVO 8 (05) tuned for 1.6 bars
and guess what? - 12 knock sum @ 5000+rpm (engine load 240 tapers to 220)
ONE QUESTION - WTF?
Old Sep 12, 2007 | 06:25 AM
4TUN8's Avatar
I'd help you but I dont know what 99 RON is in RON/MON which is the US standard.....I assume it's close to 93 octane.
What's the timing looking like? I assume it's yanking some, post the log up IMO.
Old Sep 12, 2007 | 06:28 AM
EVOLex's Avatar
Does the knock go away with fuel addition? Make sure that it's a fuel issue and not mechanical knock.
Old Sep 12, 2007 | 06:31 AM
AlwaysinBoost's Avatar
ONE QUESTION - WTF?
do you have an A/F gauge? If so what is it reading? Also check your IDC (Injector Duty Cycle), you might have blown the boost reference line off cause the car to go lean and knock.
Old Sep 12, 2007 | 07:03 AM
wrx_ua's Avatar
I have Innovate LM-1.
I've disabled lean spool. Set the spool AFR around 13 and then 11.3~11.2 to redline. I've tried both lean spool map that strikes 12 and tapers to 10.7 @ redline (ecutek fuel map)
IDC are ok @ 78%
So I ended up with 13 advance@ 6800rpm with KnockSum=0
Old Sep 12, 2007 | 01:26 PM
mplspilot's Avatar
^ How is that stock map if you modified lean spool, afr and timing???
In any case RON 99 is 94 PON. But there's also gas quality and oxyginated gas that has 10% ethanol in it. We use oxy gas here, which is better against knock. Also i would doubt that ukraine's gas is any good quality wise.
Old Sep 12, 2007 | 01:33 PM
Pd1's Avatar
Pd1
This situation doesn't seem to justify "very strange" in the thread title. It sounds like you need to lower your boost, timing, or both to get rid of the knock. Tuning 101 stuff.
Old Sep 12, 2007 | 02:06 PM
wrx_ua's Avatar
1)Our 98 RON is US 93-94oct
2)I have tried already a stock map and then began tuning - read carefully
3)Its far not the first evo im tuning ( I've recently tuned EVO9 with o2 and TBE for 25psi tapering to 21@7000rpm 11.5afr and more ignition advance then this EVO8...) on same 98 gas from Europe
Old Sep 12, 2007 | 02:18 PM
Pd1's Avatar
Pd1
Nobody on EvoM has a crystal ball. You need to be much more specific about the car you're dealing with (you said stock 05...is there such a thing?), and what it's doing. Post a log showing what you're seeing. Include wideband AFR data and 2-byte load. Also, feel free to post up your timing, AFR, and VVT maps. Don't forget to include how much boost you're running.
Live4Redline
Jul 17, 2024 07:09 AM
Ray521
Sep 10, 2015 11:10 AM
EViR
May 22, 2009 11:48 PM
tkklemann
Apr 28, 2007 05:52 AM
Ludikraut
Jul 22, 2006 09:56 PM
