PATCH: NLTS + Valet + KnockCEL
Old Sep 27, 2007 | 08:30 AM
  #166
dudical26's Avatar
Originally Posted by l2r99gst
Well, a timer in this fashion wouldn't work because if you are keeping your foot slighlty on the clutch after a shift, then NLTS is never being deactivated.
Also, for you guys stating that a setting of 1000 or 1500 is too much, you don't have to change it to a lower setting. Let me try to explain:
If you are shifting fast enough to have your RPMs drop, say 500 RPM, then whether you have your setting at 2000, 1500, 1000, it won't matter. That RPM drop is just what the limiter will be set to, in case YOU DO REACH IT. If you shift faster than the RPMs fall, then there is no need to change your RPM drop to a lower number. You should just leave your RPM drop at what the next gear RPM will come in at. So, if you shift fast enough, the RPMs will juse drop for the duration of your shift. If you do happen to shift slow enough, the limiter will kick in and have the PRMs hovering at the RPM that your next gear wants. I hope I explained that well enough to make sense.
Eric
What if you were taking you foot off the pedal completely but it was touching it again after the shift. I'm just trying to think about what might be going on here.
Old Sep 27, 2007 | 08:32 AM
  #167
Pr3z's Avatar
So On my Tephra Mods Options selection to enable these I have in the units feild
65535 for all thre options. Does this mean they are on? Whats the option for off in units?
Also I set the following
Knocksum required for CEL = 10
Load Required for CEL on knock = 20 (%)
CEL on Knock flash time = 3000 (ms)
Valet Rev Limit = 3000 (rpm)
Valet REv Limit Time = 5000 (ms)
NLTS RPM DROP = 5500 (rpm) sound ok?
NLTS TPS Threshold = 20 (%)
NLTS Speed Threshold = 20 (mph)
All these sound about right?
I am 96940011
If all works out I will send some moneys.
Old Sep 27, 2007 | 08:43 AM
  #168
Charlie_B's Avatar
^^I havent DL'd the new stuff yet, but that all seems a bit off
KS req'd for CEL - 10 is pretty high (I would go with 4, mine is currently set to 3)
Load req'd - at least 100 (under boost)
CEL on flash time - 3000 ms = 3 sec.
Valet rev limit - someone ealrier said it needed to be +3500?
NLTS RPM drop - the amount of rpm DROP when you shift, Id say no more than 2.5k
The other two look about right.
  #169
fastrob691's Avatar
PAYPAL sent, thanks again, and guys when you donate, try not to be too cheap, these guys are spending huge amounts of time giving us more tunablility than a UTEC type add on.
Old Sep 27, 2007 | 08:44 AM
  #170
Pr3z's Avatar
Aww got you. The amount you want it to drop, not the RPM to drop to. Got ya!
Thanks for the advice. Going to try it over lunch. lol.
3 seconds to long for the CEL to stay on a notice it?
Old Sep 27, 2007 | 08:52 AM
  #171
l2r99gst's Avatar
It would work if that were the case.
Eric
Old Sep 27, 2007 | 09:01 AM
  #172
Charlie_B's Avatar
Ive got mine set to 2. It was at 3, and when it flashed, it was hard to tell when the knock started/ended.
Oh, and the TPS threshhold should be at least 90-95%, not 20.
Old Sep 27, 2007 | 09:04 AM
  #173
evopower1021's Avatar
Originally Posted by A418t81
Are you 70008?
YES SIR.....
Old Sep 27, 2007 | 09:05 AM
  #174
Pr3z's Avatar
Ok thanks!
Knocksum required for CEL = 7
Load Required for CEL on knock = 100 (%)
CEL on Knock flash time = 2000 (ms)
Valet Rev Limit = 3800 (rpm)
NLTS RPM DROP = 2500 (rpm) sound ok?
NLTS TPS Threshold = 90 (%)
Thats what I got now and makes more sense now that I understand some of those better! Will try over lunch and post results and send money if all is well. I'm excited!
Does the 65535 for all three options. Does this mean they are on? This is on the Tephra Mod Options
Old Sep 27, 2007 | 09:08 AM
  #175
Originally Posted by tephra
Can I get someone else with 94170008 report if the Valet mode works or not?
I HAVEN'T BEEN ABLE TO GET THE VALET MODE TO WORK
Old Sep 27, 2007 | 09:51 AM
  #176
AlwaysinBoost's Avatar
I have the ROM but I need your email address to send it to you... I tried your profile but it says the address in not public.
Old Sep 27, 2007 | 10:10 AM
  #177
phenem's Avatar
Ok thanks!
Sounds like the endian big/little issue here or you are not using the correct ROM to transfer you stuff over to.
What XML file did you use in his download, there are two, one for ECUFlash 1.30 and below and one for 1.31 and above, make sure you use the correct one or you data will be messed up. Sounds like this is your issue.
~Zach
Old Sep 27, 2007 | 11:01 AM
  #178
Evoryder's Avatar
does the NLTS work? I haven't tried that yet...
Old Sep 27, 2007 | 11:28 AM
  #179
Pr3z's Avatar
~Zach
I used
96940011 UNTESTED possibly not stock!!!
THe one for 1.30 and below which is what I have.
It did not work. Am I supose to do anything with the .bin file?
I am going to try the new version of ECU scan and try again with eh 1.31 and up.
Old Sep 27, 2007 | 11:35 AM
  #180
Charlie_B's Avatar
^^You do know that you need to copy all of your maps to the ones he provided, correct?
