PATCH: NLTS + Valet + KnockCEL
Old Sep 26, 2007 | 04:15 PM
  #76
cossie1's Avatar
Nice work, sounds very interesting.
Is there any chance of 90550001 (I have an Evo6 running an Evo7 ecu).
Old Sep 26, 2007 | 04:21 PM
  #77
evopower1021's Avatar
i understand that part but where do you adjust for valet mode and nlts
Old Sep 26, 2007 | 04:26 PM
  #78
Ph3n1x's Avatar
The tables should appear at the bottom
Im assumming u copied all the information to ur specified .xml definition in the ECUflash folder?
Old Sep 26, 2007 | 04:27 PM
  #79
Evoryder's Avatar
Originally Posted by Phenix_fyah
96940011 tested, car refused to start.
THought I was the only one ....94710008 = no start
Old Sep 26, 2007 | 04:29 PM
  #80
blackbichGSX's Avatar
I am down for some donation too. Looking for 94170015 image . Can't wait. Any chance for some anti-lag when you are sitting still? Have it activated below a certain speed, with the clutch in, and set the timing (usually 10 deg) That would be the end all!
Subscribed!
Old Sep 26, 2007 | 04:31 PM
  #81
when i unzipped the file there was 3 icons in there. then i used ecuflash to open and there was only 1 icon. so i just copied everything on my map to the one supplied in the folder. there wasn't anything else
Old Sep 26, 2007 | 04:33 PM
  #82
what am i not getting here?????
Old Sep 26, 2007 | 04:36 PM
  #83
kreionic's Avatar
the other 2 files that you copy into your rom id xml. One was for ecuflash 1.30 and lower and one was for ecuflash 1.31 and higher
Old Sep 26, 2007 | 04:38 PM
  #84
dudical26's Avatar
Its the same process as his knock flash.
The other two files are text files, inside they have text that needs to be added to the defenition file for the ROM.
Check your ecuflash version
then open the corresponding text file
copy all the lines in the file and add them to the following file
c:/program files/openecu/ecuflash/romdata/mitsubishi/evo/(click the file that is the version of your ROM)
  #85
l2r99gst's Avatar
Originally Posted by dudical26
I am having some weird issues with the patch.
I'm not sure whats going on, it seems like when I shift really fast I am in the next gear and off the clutch but the car is still trying to catch up with me.
Like it is still stuck in the NLTS rev limiter for a second while I am already in the next gear waiting to go.
Check out the log, you can see me shift and then it is still oscillating RPM's
Make sure that you are taking your foot completely off of the clutch pedal after your shift. Some people have the habit of resting their foot on the clutch pedal, but since NLTS uses the top clutch switch for activation, even the slightest touch of the pedal will activate it.
Eric
Old Sep 26, 2007 | 04:39 PM
  #86
l2r99gst's Avatar
For the people with starting issues, I had that issue once when I was testing for Tephra. It turned out to be a bad ROM I think. This was for 96940011. He used a new ROM for me and all was well again.
So, maybe it is just a bad ROM?
Eric
Old Sep 26, 2007 | 04:40 PM
  #87
Cyloc's Avatar
don't forget to change the immobilizer code so it matches your factory one
Old Sep 26, 2007 | 04:43 PM
  #88
Ph3n1x's Avatar
did all that....
Old Sep 26, 2007 | 05:16 PM
  #89
Magnumpsi's Avatar
I need to test this on a car.
Anyone in Phoenix want to come by and let me test let me know, I will buy you a six pack.
And look for my donation as this is so awesome. I can't tell you how much of a nerd I am when I get so excited about something like this I pace around!!
Mitch
Old Sep 26, 2007 | 05:20 PM
  #90
Evoryder's Avatar
So how is it 1 or 2 guys with the same ROM have had success... Sounds like a bad rom, I ran through every single parameter I could think of...
Eric
...already did that, and said I had that covered.
did all that....
+1
