open loop load?
Old Oct 31, 2014 | 12:45 PM
  #76
todd6027's Avatar
Originally Posted by bruce974
I want to set my afr at 15.5 at idle and cruise for the best fuel economy.
- what is the best, openloop for the full time or not?
- Near the rev limiter, I loged my afr at 9.6:1, but I saw 8 knocksum, yet I did not tune my ignition map and I have 15 psi of boost at the rev limiter.
- when I loged knocksum, what ignition map do I modify, high, low, or both?
closed loop for idle and cruise
9.6 is nearly 2 full points too rich
have a read
https://www.evolutionm.net/forums/ec...-tune-evo.html
Old Nov 2, 2014 | 03:22 AM
  #77
bruce974's Avatar
Originally Posted by ronaldo9
9.6:1 on pump gas? That is very rich and bare in mind that is also not ideal. I would lean that portion out a bit if it were my car. I modify both high and low ignition map. I keep the low ignition map a bit more conservative than the high ignition map.
yes 9.6:1 at WOT but I have 8 knockshum too.
If I lean that portion, I should have more knocksums yet?
How to verify if the ecu runs in openloop mode?
Old Nov 2, 2014 | 08:42 PM
  #78
X Double Dot's Avatar
Leaning from 9.6:1 won't necessarily mean more knock, there is a point where too much fuel (your case) is bad. Bump that closer to 11.2 for starters. At 9.6:1 its doubtful ur even getting close to complete combustion of all that fuel.
As for open loop, just change the two "open loop load vs rpm tables" to 0 to force open loop all the time. This seems to be what most do. To verify, try logging ur short term feedback trim, guessing it wouldn't be oscillating
Old Nov 2, 2014 | 08:45 PM
  #79
Shame on me, I went back and reread what u had already done, sounds like uve got the tables already. How do u know its not working ?
Old Nov 3, 2014 | 08:50 PM
  #80
bruce974's Avatar
I learned something, I thought if I leaning from 9.6:1 to 11.2:1, the engine would knock more with the same ignition?
How can I accurately identify differents cells in the fuel map ( idle/cruise, spool, peak?)
I don't have table called "OL vs RPM tables
this is my rom :
Old Nov 3, 2014 | 08:58 PM
  #81
bruce974's Avatar
I have tried to use "full time openloop" in ecu periphery option, but my AFR oscillates between 13 and 17 when this option is activated and idle becomes unstable.
Old Nov 3, 2014 | 09:36 PM
  #82
bruce974's Avatar
I have tried to log 'jdm map" too and for me the values have no sens.
I have 15 psi at WOT on my mechanical gauge and the values are very different in evoscan
Look at my log please
I would have preferred the values in "bar"
Old Nov 4, 2014 | 11:19 AM
  #83
Do you actually have a JDM map sensor? If you only have a stock usdm sensor the scaling would more than likely be off, explaining why ur logging 32.x vs 15.
Old Nov 5, 2014 | 03:09 AM
  #84
bruce974's Avatar
Yes I have a jdm map
Old Nov 5, 2014 | 09:04 AM
  #85
Hmmm, do you have to subtract out atmospheric pressure (14.7psi at sea level)? That would get u closer to the 15 psi ur gauge is reading
Old Nov 8, 2014 | 03:20 AM
  #86
bruce974's Avatar
my eval for jdm in evoscan is 0.19347*x-14.7.
Need I to subtract 14.7 in this eval? (0.19347*x-14.7)-14.7?
5LEEPERISAH23I
Mar 7, 2016 12:04 PM
SnailSpeed
Oct 22, 2012 10:00 AM
rrkpitt15
Sep 16, 2011 09:40 AM
Jim in Tucson
Nov 21, 2010 09:29 AM
mrfred
Sep 29, 2009 12:35 PM
