Mod request: Knock count buzzer
Old Oct 16, 2007 | 11:42 AM
Jeff_Jeske's Avatar
Exclamation Mod request: Knock count buzzer
Is there any way to link knock count to a buzzer or an output that I can connect to an aftermarket noise maker?
I love that we can make the CEL flash but during a lapping day I can't gaze at the dash as often as I would like. My radar detector scares the crap out of me when it goes off. I would like a similar device for knock.
What would it take to make this more than vapor ware?
Old Oct 16, 2007 | 12:09 PM
MR Turco's Avatar
Or make the turn signal speaker go off. Not that it is very loud.
Old Oct 16, 2007 | 12:28 PM
donour's Avatar
Seat belt bell? Door ajar annoy tone?
d
Old Oct 16, 2007 | 12:33 PM
JohnnyBoy427's Avatar
Find an old radar detector with a working speaker at a pawnshop and use that.
Old Oct 16, 2007 | 01:05 PM
dudical26's Avatar
Bez had a patch that would give power to the rear 02 sensor circuit with knock. He used it by wiring a small light into the circuit but you could just as easily wire in a piezo buzzer which can be bought from radio shack for a few bucks.
Old Oct 16, 2007 | 01:10 PM
Jeff_Jeske's Avatar
This could also be used as a fail safe for something like alchy/meth. Hear the buzz get out of the throttle. That would probably be plenty of failsafe for those of us running about 350whp.
Old Oct 17, 2007 | 11:27 AM
Erik@MIL.SPEC's Avatar
Next thing we're going to have is the "Knock Count Jack-in-the-box" mod
Old Oct 17, 2007 | 11:35 AM
trinydex's Avatar
how about an ecu controller thermostat for my kegerator in the back seat?
Old Oct 17, 2007 | 12:06 PM
Jeff_Jeske's Avatar
I'm not sure why you wouldn't want an audio and visual warning. I would prefer audio over visual. I'm sure its doable and that it wouldn't take much to pull it off.
Old Oct 17, 2007 | 12:28 PM
Evo_Jay's Avatar
What about the patch when a certain amount of knock cuts boost to WG psi. That what i would want for AI/MI.
Old Oct 17, 2007 | 01:12 PM
dudical26's Avatar
That would be pretty cool, although sometimes if I am in the middle of a race I would rather just finish without having it lower my boost. And then I can look at the log and adjust the tune after the run.
Old Oct 17, 2007 | 01:14 PM
trinydex's Avatar
that is boost correction...
Old Oct 17, 2007 | 02:01 PM
travman's Avatar
I really dont see the point....isnt the cel flashing enough of a warning?
Old Oct 17, 2007 | 02:07 PM
Evoryder's Avatar
buzzer would be good too...i already have an additional bright bulb hooked up to my ecu pin so when the cel flashes so does the LED...you can always hook a line to that.
I will add, the buzzer could get annoying. My led gets my attention enough just through peripherals alone.
Old Oct 17, 2007 | 02:24 PM
dudical26's Avatar
So there you have it, you can easily add an LED or Buzzer to the existing CEL light patch.
