How To Tune an Evo
Old Oct 15, 2009 | 01:43 PM
  #631
Thomasevo's Avatar
thanks for the write up
Old Oct 17, 2009 | 07:23 AM
  #632
mguyott3's Avatar
Originally Posted by GottaZtt
Greetings,
I currently reside over sea's and Need help tuning a friends Evo 7. I have used OpenECU on Evo 8's and 9's and 10's in the U.S. but I have tried over and over and I simply can not connect to their ECU's. I have tested EVO 7 and 9 with same result. using ECU Flash version 1.42
the vehicles here in are mostly JDM. does anyone have a solution?
Thank You!
did you ever figure this out
Old Oct 17, 2009 | 03:09 PM
  #633
GottaZtt's Avatar
^thanks for the concern, but no i have not, I am puzzled that no one has an answer!
Old Oct 20, 2009 | 07:42 PM
  #634
NightCat's Avatar
Hey, this might sound stupid but I'm curious as to what generated the following images
and
Were these generated with EvoScan? If so, how? what settings were selected?
Also, what inputs would you suggest to start initial logging while tuning? (RPM, TPS, etc)
Old Oct 20, 2009 | 09:56 PM
  #635
03lances's Avatar
I think he was using the dataloglab program for those although if I am wrong someone please tell us how to do this as it looks to make things much simpler
Old Nov 6, 2009 | 03:48 PM
  #636
NightCat's Avatar
A Few questions, probably been answered already but theres 43 pages and Ive already read through it twice :P
How do you configure the ECU to read 2byte load? cause right now im logging under loadcalc.
And also, just curious as to what you guys log? Im currently logging,
- Knock Sum
- Engine RPM
- Load Calc
- Boost(MDP)
- Speed
- AFR Map
Yet, all my Boost levels are reading waaaaaaaaaay too high. do I need to reconfigure something to make it ready accurately? its saying like 40psi and like 18psi at idle.
Old Nov 6, 2009 | 04:15 PM
  #637
Evo_Jay's Avatar
and
that program is called Logworks. It comes with the innovate WB 02's. It also has a plug-in, so it can log everything that evoscan can, though logworks.
Old Nov 6, 2009 | 04:25 PM
  #638
NightCat's Avatar
Yea, I figured that much out. Im using EvoScan and ECU Flash right now but some of the data seems off and Im curious as to how I can get it to use 2byte load.
and if i need to calibrate boost...its reading like 40+psi in evoscan and Im like "wtf"
Old Nov 6, 2009 | 05:25 PM
  #639
Evo_Jay's Avatar
Do you have a JDM/EVO X map sensor?
Old Nov 6, 2009 | 05:57 PM
  #640
NightCat's Avatar
Nope, All stock sensors.
Old Dec 10, 2009 | 10:02 AM
  #641
Jazzie604's Avatar
Have you switched the readings in evoscan to think it is a 3/4bar sensor? sounds like it is reporting as one.
Old Jan 2, 2010 | 08:04 PM
  #642
Methodical4u's Avatar
does this apply to the X as well or should that just be seperate? I would guess rules are rules right?
Old Jan 21, 2010 | 03:23 AM
  #643
EVOXTIMES's Avatar
I was thinking the same thing. I would assume the theories still apply.
Old Jan 23, 2010 | 10:59 AM
  #644
JorgeYaHeard's Avatar
Great write up. thanks for all the hard work and time you put into this.
Old Feb 1, 2010 | 12:52 AM
  #645
EvolutinIX's Avatar
This is the best thread I've ever read..
