How To Tune an Evo
Old Feb 1, 2010 | 08:32 PM
  #646
3SgteGuru's Avatar
Ok I got bored and was reading this thread then I saw the formula and nj1266's suggestion to make and excel document to calculate the AFR. I am pretty sure I am not the first to make one but I would be more than happy to share it with you guys.
File Type: zip
Old Feb 2, 2010 | 05:28 PM
  #647
3SgteGuru's Avatar
I also Made an Excel document for big maps
File Type: zip
Old Feb 3, 2010 | 09:38 AM
  #648
yokozuna's Avatar
Ι think that this thread is a top one for our first steps in tunning our EVO guys. One thousand times to say thank you is not enough.. Keep on the good work. By the way, come to Greece for holidays..Its really good :P
Old Feb 5, 2010 | 03:23 PM
  #649
5LEEPERISAH23I's Avatar
wow awsome job.. makes me want to tune my car.. but i dont know if i have the guts to do it... reading this makes me understand how tuning works tho
Old Feb 8, 2010 | 04:37 AM
  #650
Domolution's Avatar
Naji just knows his ****!
Old Feb 8, 2010 | 11:48 AM
  #651
Domolution's Avatar
Yeah, alottt of procedures to it. \:
But once you get it down, i am sure you'll be golden from there, haha.
Old Feb 15, 2010 | 07:42 PM
  #652
1slick1's Avatar
EVO IX JDM Map
Do have any JDM map for 95 or 97 octane?
Thanks,
Old Feb 19, 2010 | 09:14 PM
  #653
SPD_FRK's Avatar
I realize I am still a new guy around here, but this is the 3rd time I have read the information and it still helps learn more each time. I know this is specific to the Evo, but this is honestly the best tuning guide I have read that could easily apply to myself with the Galant platform I am working on.
Excellent, and thorough job done with this
Old Feb 25, 2010 | 05:24 PM
  #654
jos's Avatar
jos
good info for do it ur self tuners
Old Mar 12, 2010 | 01:41 PM
  #655
mitsuEVO8kid's Avatar
This thread just needs a FAQ and it would be perfect because I have some really noob questions. I have been reading for a couple days, but I dont understand a couple things in the "Timing section".
1. Naji explained in the first advanced timing map that the spark plug should fire between 3*2*...How does one know/think when the spark plug will fire at that precise point and not at 3*3* or something else?
2. After logging and tuning a map in 3rd/4th gear, do the changes that the tuner made affect all of 1st, 2nd, and 5th gear as well? In other words, does the ECU automatically adjust to the changes made in the 3rd and 4th gear logs?
Once again, I apologize if this was posted elsewhere, but I have not been able to find the answers to those questions. I'm taking notes and studying with this guide and forum before I attempt to tune my own car.
Old Apr 9, 2010 | 08:27 AM
  #656
PAdutch's Avatar
Great info. Subscribed for future tuning plans.
Old Apr 9, 2010 | 09:31 AM
  #657
Raptord's Avatar
RE #2, the changes made are based on 3rd and 4th gear logs because since they take longer to do you have more samples from the log, however doing it in 5th would mean you'd be going ridiculously fast. The ECU uses RPM and Load (which is more or less how much air is going into the engine) to decide on how much fuel to use, the timing advance to use, etc. It is independant from which gear the car is in.
Old Apr 9, 2010 | 07:44 PM
  #658
JFuego777's Avatar
Regarding question 1:
I believe that 3*2* means the timing should be between 2 to 3 degrees before TDC, which would be adjusted in the timing tables by you.
Old Apr 16, 2010 | 02:22 PM
  #659
boldaserick's Avatar
im a nube and also curious...a wide band O2 gauge can not be used instead off the meter for the tuning right? why?
Old Apr 26, 2010 | 10:56 AM
  #660
irishone337's Avatar
Hey. I'm using the newest version of ECUFLASH and I'm having trouble setting the injector latency and scaling. I'm new to all of this and when I open the tables it's not allowing me to change any of the numbers. Thanks in advance.
