MIVEC disassembly notes
Old Nov 26, 2007 | 08:38 AM
mrfred's Avatar
Just getting started on decoding the MIVEC algorithm. First tidbit is the MIVEC range. My recollection is that people are saying its 0 to 30 deg. The software code limits it to 0 to 28.8 deg, so anything higher than that in your MIVEC maps gets pulled down to 28.8 deg.
More later...
Old Nov 26, 2007 | 08:52 AM
vmrevo9's Avatar
Veteran: Air Force
subscribed
Old Nov 26, 2007 | 09:36 AM
JohnBradley's Avatar
Interesting. Its the factory service manual that said 0-30 degrees.
Old Nov 26, 2007 | 09:40 AM
TouringBubble's Avatar
maybe -1.2 to 28.8?
Old Nov 26, 2007 | 12:06 PM
Evo_Jay's Avatar
I thought it only went to 28.8
LOL at all these people saying they use "30s" and can feel a difference.
Old Nov 26, 2007 | 12:09 PM
Erik@MIL.SPEC's Avatar
Maybe they have guitar amps that can go to 11?
Old Nov 26, 2007 | 12:12 PM
mrfred's Avatar
Originally Posted by TouringBubble
maybe -1.2 to 28.8?
The limits are definitely 0 to 28.8 in the ECUFlash scaling of the hex values. I still haven't verified the scaling used by ECUFlash though. Most of the scalings that I've checked have been correct, but there have been a few errors here and there.
Hey JB, does the FSM say "0" to "30"?
Old Nov 26, 2007 | 03:44 PM
evo8426's Avatar
subscribed
Old Nov 26, 2007 | 03:54 PM
The factory service manual says that the intake valve opens (variable) 0-30* BTDC and closes 80-50* ABDC. I might have the actual piston event labelled incorrectly but I listed it in the original MIVEC tuning thread somewhere.
As far as the wags making reference to Spinal Tap, while I cant explain why it would matter if the hex is limited to 28.8* (I assume a value of 255) there are dyno'd torque improvements running 30*. A certain tooner that has left for the green pastures of BMW and Porsche used to set his maps to 33* and it would throw a MIVEC out of range code (like P1175 I think).
Old Nov 26, 2007 | 03:55 PM
Evo_Jay's Avatar
I remember that. Maybe its this...
maybe -1.2 to 28.8?
Old Nov 26, 2007 | 04:05 PM
I knew I posted it in there somewhere:
https://www.evolutionm.net/forums/sh...5&postcount=99
Old Nov 26, 2007 | 04:12 PM
Re: Spinal Tap. Was just trying to be funny...not intended to be a swipe at anyone's expense. And I thought I read somewhere said tuner would input values even higher than 33*.
Old Nov 26, 2007 | 04:19 PM
Evo_Jay's Avatar
That certain tooner also had maps that had 20+ knock count.
Old Nov 26, 2007 | 04:22 PM
That would line up with my experience with said tuner, although I only had 12-16 IIRC.
Old Nov 26, 2007 | 04:26 PM
honki24's Avatar
lol your signature is priceless. Rediculous, but priceless.
