wastegate solenoid on/off?
Old Dec 8, 2007 | 09:08 AM
nothere's Avatar
is there a way to disable the stock boost solenoid without it triggering a cel?
btw how does one interpret deactivate on, reactivate off etc.
Old Dec 17, 2007 | 09:12 PM
aznj's Avatar
i think by using ecuflash and setting your boost cut setting to a value you will never hit (i assume your using some other kind of boost controller) this will just render the stock boost solenoid obsolete
i'm running a mbc because my stock boost solenoid went bad causing the cel. I yanked my stocker and the cel only comes on now when i boost over 19 psi.... obviously not a coincidence. i still have yet to change the values on my ecu, i guess i should get on that.....
Old Dec 17, 2007 | 09:36 PM
tephra's Avatar
trying to save that extra 80grams ? :P
just leave it attached but loop the hose back through itself so it doesn't fill up with dirt or anything
external EBC right?
Old Dec 18, 2007 | 05:47 AM
nothere's Avatar
thought I lost the boost solenoid, so I bought another, that is when I found it.
using an ebcs, now have the stock piece wired up and looped back, no cell, thanks.
you got me with the 80 grams.
Old Dec 18, 2007 | 06:18 AM
C6C6CH3vo's Avatar
Same here with mbc, but to think of a solenoid with a whole list of 3d maps already defined that control it, just hanging there not doing anything.
I have plans for it though, hint: egr exhaust is a powerful antidetonant that when rerouted through the IC and cooled with a blast of methanol, and since cast exhaust pressures can be much more than charge, use the solenoid to controll the egr rerouted to charge.
Old Dec 18, 2007 | 06:25 AM
jcsbanks's Avatar
IX JDM doesn't mind if it is unplugged, if US models give a CEL then it is something to look at turning off?
Cobrajetguy
Mar 9, 2015 03:44 AM
riksride
Aug 27, 2012 11:34 AM
luischav3z
Lancer Troubleshooting
32
Jan 6, 2009 06:10 PM
Mattjin
Oct 17, 2008 03:40 AM
RalliArtEvoVIII
Nov 19, 2004 01:07 PM
