PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Mar 15, 2008 | 08:02 PM
  #436
tephra's Avatar
Hey guys,
Just letting you know im back from holidays - so this week I will be putting up the V5 thread, and slowly doing ROMID's for V5.
Probably not much point in testing V4
Cheers
D.
Old Mar 15, 2008 | 08:15 PM
  #437
bnice01's Avatar
Sweettt
You Rock Man
Old Mar 16, 2008 | 12:02 AM
  #438
silex's Avatar
Agreed! I'm going to setup my ALTMAP button before you release this!
Old Mar 16, 2008 | 12:10 AM
  #439
Jameson_IXMR's Avatar
Oh sweet finally a non-UTEC based map switching for the 9!! Thanks Tephra!
I do not/have never had the ICS system. what type of button is used so I know what to hook-up? SPDT? DPDT? momentary? on? on/off? Push to interupt? Thanks
Old Mar 16, 2008 | 12:13 AM
  #440
silex's Avatar
Look at Jack_of_Trades' sig and click on the HERE link on how to build or buy a harness as well as info on the piece parts
Old Mar 16, 2008 | 01:30 AM
  #441
Jack_of_Trades's Avatar
Just follow my sig I still need to update the diagrams but you should find a 4.7v 1 watt Zener Diode online or at a local electronics store, rather than the 5v zener diode avaliable at radioshack. With its low tolerance, it could exceed exceed 5v and possibly damage the ADC input circuit/ECU. Its not too likely but Tephra feels better having people staying below the 5v mark.
Old Mar 16, 2008 | 05:03 PM
  #442
Evoryder's Avatar
Jamie - should the ics switch still work with the new patch? It still switches maps...but your kit doesn't.
Old Mar 16, 2008 | 05:29 PM
  #443
I believe tephra added a table to determine whether you want to use the alt map harness OR the ICS switch to switch maps in v5.0. Do you have a beta test version of 5.0 or v4? Ideally, if you have the alt map harness, you want to use just that to switch maps. If you turn the switch ON, it locks the ECU in the Alt maps so the ICS switch can't shut it off. What do you have the Alt Map switching point set to in ECUFlash? The normal function of the ICS switch should still work fine (i.e; turn the ICS auto mode on or off and manually spray the IC).
Old Mar 16, 2008 | 07:57 PM
  #444
tephra's Avatar
Yeah V5 was the first to support the altmap switching harness (well V4.7 but that wasn't public)
Also in V5 you choose EITHER AutoICS OR ADC0F for switching, not both
Cheers
D.
Old Mar 16, 2008 | 08:47 PM
  #445
Evoryder's Avatar
Maybe I need to upgrade to v5.0...I haven't tried the 2volts to switch maps that you said jamie.
Old Mar 16, 2008 | 08:57 PM
  #446
tephra's Avatar
pm me your email address and ROMID ill send you a V5 if I have it
Old Mar 16, 2008 | 09:30 PM
  #447
mr2driver's Avatar
This is probably a newb question, but I am currently on the 88590013 and I want to switch to the newer 88590015 with stock tables and v5 patch. After this v5 patch is completed for 88590015 can I just use that bin file, or do I need to copy the tables over from a stock 88590015 bin file? TIA
Old Mar 16, 2008 | 09:56 PM
  #448
You will need to copy over all of your settings into the new 015 bin file and save it.
Old Mar 17, 2008 | 03:57 AM
  #449
Evoryder's Avatar
done
Old Mar 17, 2008 | 02:23 PM
  #450
evo082006's Avatar
When does V5 release?
