PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Feb 12, 2008 | 09:39 PM
  #376
VT Mitsu's Avatar
Originally Posted by tephra
stock boost control only i'm afraid, so if you have an aftermarket ebc and want boost switching then you will need to get rid of it.
your cheapest/best bet would be to get a a 3port GM BCS and a JDM MAP and do MrFred's direct boost control...
re 08 vs 14 - thats still to be decided, but I can't see why you can upgrade to 14...
Really don't need it to switch. Actually would be happy to just have boost control that didn't need adjustment from day to day due to the wild temp fluctuations here in Vt. ...2 days ago, 34 dgrees, today minus 9. 40+ degree delta to deal with...
I still have all the stock boost control pieces...need to look up the direct boost control from MrFred. ( I am guessing...another patch that has a table/cell controllable through ECUFlash where a target boost can be entered...I hope?)
MrFred's thing only works with the pieces you mentioned, yes? 3bar vs 1 bar USDM?
Also did you mean to say "I don't see why you can't upgrade to 14..." Just though I had seen people who never got the p300 code have it pop up when upgrading just to have the 0014. Maybe I'm off base... Just happy it has never reared it's ugly head in my car. Still wondering what the wink may end up being
Thanks for the response, I am still trying to wrap my head around how all this works :]
Old Feb 12, 2008 | 10:30 PM
  #377
mrfred's Avatar
If all you want is better control over boost, then either my load-based or psi-based boost control mods will work for you. Just need a JDM MAP sensor and a modified boost hose (restrictor pill or bleeder).
Old Feb 13, 2008 | 02:25 PM
  #378
chmodlf's Avatar
Luckily I have only had one P300. Happened once when I installed the Random Tech HFC (installed for about 2 yrs.)--which seems to have fallen out of favor with mrfred of late...
Not that I am a tree hugger, but I wonder how efficient a 100cell cat is at reducing emissions.
Old Feb 13, 2008 | 03:34 PM
  #379
Jack_of_Trades's Avatar
Yeah, he meant "can't". The 94170008 is upgradeable to the 94170014 and shouldn't have any issues.
Old Feb 14, 2008 | 09:24 AM
  #380
Tek3Evo's Avatar
What is the enable/disable routine in the car for the auto-valet option. I've seen references to TPS position but no instructions.
Old Feb 14, 2008 | 09:29 AM
  #381
honki24's Avatar
check first page of the V2 thread, all instructions are there.
Old Feb 14, 2008 | 09:42 AM
  #382
Tek3Evo's Avatar
thank you. guess I was searching too hard and didn't look at the first page of the old version.
Old Feb 14, 2008 | 02:56 PM
  #383
tephra's Avatar
this will go in the new thread BUT for V5, setting autovalet to 1 will mean it automatically does valet limiter everytime.
then to disable (or enable) the revlimiter you need to hold TPS @ 100% for xyz seconds...
Old Feb 16, 2008 | 06:31 PM
  #384
chmodlf's Avatar
Originally Posted by Jack_of_Trades
The 94170014 is the P0300 fix for the 0008, which he definitely will be doing.
No the 94170015 is the latest fix for the P300 the 94170014 is the first release for the P0300. There are about 13 differences in the two ROMS.
Shouldn't tephra be working on the latest version for the 03s so the mods by him and others be applied to one ROM vs maintaning two or three ROMs?
Old Feb 16, 2008 | 06:37 PM
  #385
Ahh, I didn't know the 0015 was a fix as well. My buddy thats a Mitsu tech says they still use the 94170014 for P0300 fixes today, per Mitsu's request.
Old Feb 16, 2008 | 06:42 PM
  #386
chmodlf's Avatar
Mabey they did not like the later version or it addresses the P0300 and other issues. At any rate the ROMs are pretty much identical. It looks like the 15 is a small tweak of values to further address the P0300 issues.
Most of the differences are seen on the attached image
Attached Thumbnails PATCH: KNOCKCEL+NLTS+AltMap (V4)-14vs15.gif
Old Feb 18, 2008 | 12:04 PM
  #387
Youngsyr's Avatar
Originally Posted by evo828
Dave - for ROM like 96530006 where the only patch was the Knock Cell flash - will you be able to patch with the AltMap switching? No need for NLTS and all those other nice features - but the alt map + johnbanks live tuning would be very appreciated
Nice work to all involved!
A 93660005 owner here drooling at the mouth with anticipation over AltMap switching.
Old Feb 18, 2008 | 12:45 PM
  #388
Youngsyr's Avatar
As long as your setup is capable of outputting 5v when everything is "ok" and 0v when something is wrong then it will work just fine.
so yeah you would setup your highboost on the altmap and then a failsafe boost on he standard maps...
Cossie - yours and BarryC's will be the first ROM I do, coz ive been promising for ages todo so
Talk about landing on your feet, it seems I share the same ROM ID (93660005 - if I read correctly)!
Needless to say there will be a donation winging its way over when it is released!
Old Feb 18, 2008 | 10:49 PM
  #389
tephra's Avatar
oh man, doing 96940011 at the moment...
there is bugger all free space in this rom... going to be quite hard do fit it all in.
I will probably have to throw out my "standard" for putting the extra maps in the ECU for this one
Old Feb 18, 2008 | 10:56 PM
  #390
RazorLab's Avatar
