PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Feb 5, 2008 | 02:16 PM
  #271
tephra's Avatar
yeah I am 99% sure its related to mivec advance+retard + interpolation each way depending on how much retard and advance.
but given the stock maps are basically the same (+/- 1 either side of #2) then I dont think its a big deal.
V5 will be the next release, final testing on my car today. However if everyone agrees to merge 1/2 and 3 then i'll do that and release
differences between V4.2 and V5:
- Boost map switching (BDEL and BWGD)
- Injector Scaling Switching (with the above now provides a faily complete E95 solution
- Map switching using either the AutoICS button (for ICS dudes) OR wiring up a seperate switching (for nonICS dudes + Meth users)
- RearO2 simulator (MrFred's algorithm !!!)
Cheers
D.
Old Feb 5, 2008 | 02:17 PM
  #272
RazorLab's Avatar
tephra you seriously rock.
Old Feb 5, 2008 | 02:18 PM
  #273
tephra's Avatar
Oh I forgot to add
- Flattening the BDEL/BWGD maps into 1 (for simplicity)
- Doing the same for the IX timing maps if we agree!
  #274
TouringBubble's Avatar
Any chance that a new method of switching will emerge for the IX any time soon? I'm just worried that I'll go add stuff to my ECU and then you'll come up with an easier way to switch ...
Old Feb 5, 2008 | 02:20 PM
  #275
Jack_of_Trades's Avatar
Who would have thought, the best ECU upgrade for the evos would end up being....the stock ecu! lol I'm gonna feel bad for all of the AEM stand-alone guys. The only reason I see people going to the AEM is the MAF setup for the most part.
Old Feb 5, 2008 | 02:24 PM
  #276
tephra's Avatar
no I think we will settle on the wiring the external switch for the IX's without ICS.
It's fairly simple to do and provides a "global solution" for meth users..
right on Jamie
Old Feb 5, 2008 | 02:30 PM
  #277
And any single wire I/O switch will work I assume?
I'm really looking forward to this ...
Old Feb 5, 2008 | 02:32 PM
  #278
tephra's Avatar
I will leave all wiring discussion upto Jamie, since he is the one who did most of the work getting it going
  #279
scheides's Avatar
EvoM Moderator
Tephra, will this switch be compatible with the Aquamist HFS-1 and -5? I'm going to be ordering one soon, and would LOVE to help you guys test this.
So if the system is on and active, high boost and alky. Failsafe and boost drops (v5 right?...eventually) and switch to alt map. Power DDS off and the same thing happens. Alky, no alky at the push of a button!
Old Feb 5, 2008 | 02:51 PM
  #280
cossie1's Avatar
wow is all I can say
Just hope 90% of this will work with a 7 rom
Old Feb 5, 2008 | 02:52 PM
  #281
tephra's Avatar
As long as your setup is capable of outputting 5v when everything is "ok" and 0v when something is wrong then it will work just fine.
so yeah you would setup your highboost on the altmap and then a failsafe boost on he standard maps...
Cossie - yours and BarryC's will be the first ROM I do, coz ive been promising for ages todo so
Old Feb 5, 2008 | 02:55 PM
  #282
Doubtful, I think the addition of the switch harness is the easiest solution. The IX's don't have much wiggle room here.
Also, I will be offering a universal failsafe control unit which accepts three +12v inputs, three +5v inputs and three ground inputs to trigger the ADC input. That way no matter what alky kit you have, you can have it trigger the alternate maps automatically. This won't be available for at least anohter few weeks though.
Old Feb 5, 2008 | 02:58 PM
  #283
BarryC's Avatar
Fair Play Nice one Dave
Old Feb 5, 2008 | 03:02 PM
  #284
You can set it up either way Teph. You just need to decide whether the ALT maps are you "less aggressive" maps or your "more aggressive" maps. That way it doesn't really matter whether or not the trigger is active when things are 'ok' or if things are in 'failsafe' mode.
Old Feb 5, 2008 | 03:43 PM
  #285
burgers22's Avatar
Pah! They're not even proper 7's Damm cuckoo's
MB
