PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Jan 16, 2008 | 07:00 PM
  #226
tephra's Avatar
lol - did you have it turned off?
Old Jan 16, 2008 | 07:55 PM
  #227
Profoxcg's Avatar
high octane versus low octane
can I tune for to run 87 octane? I guess what I am asking is, when or how does the ecu know which map to use? can this be logged?
Old Jan 16, 2008 | 07:58 PM
  #228
tephra's Avatar
you can run whatever tunes you like, however it is upto you to choose the right tune.
The ecu won't swap to the right map automatically... If you want to log which map the ECU is using then I can provide evoscan xml for that...
  #229
Jack_of_Trades's Avatar
Its a manual thing, not automatic (at the moment). The user decides which map to activate. You COULD tune for 87 octane if you planned to NEVER boost while running that map I suppose.
In the future (not fully designed for this purpose yet), this mod will allow users to interpolate between the alt maps and the standard maps. This would be helpful for users running standard gas or a mixture with E85. An ethanol sensor can tell the ECU the % of ethanol in the mix.
Old Jan 16, 2008 | 10:42 PM
  #230
Profoxcg's Avatar
yeah please, sounds good. can you sent it to me? e-mail me or something.
Old Jan 16, 2008 | 10:46 PM
  #231
Profoxcg's Avatar
how do you do that? what do you mean its a manual thing?
why can't i boost with on 87? check this out, lets say i tune for 10.0 at redline (which I will never get to in 87) and just pull timing.
I know the car will be slow, but i would be more economic. then later when tephra makes an update for 88590015 to switch maps w/ an external push button then I can go to the gas station refill with 93 octane and switch maps or something.
Old Jan 16, 2008 | 10:57 PM
  #232
tephra's Avatar
Profoxcg, Once I release 4.7 I will get some evoscan def's out as well...
Old Jan 16, 2008 | 10:59 PM
  #233
Profoxcg's Avatar
sound good thanks !
Old Jan 17, 2008 | 03:59 AM
  #234
10.0 AFR? Even still, 87 octane doesn't have NEARLY enough resistance to detonation to not knock like CRAZY! Even if you ran 12psi by bypassing the wastegate solenoid and running a vacuum line directly to the Wastegate actuator you would still knock. I don't care how much timing you pull, the increased heat from the compressed air in the combustion chamber is enough to pre-ignite the fuel mixture.
Just trust me, boosting on 87 octane is the worst idea ever for your engine.
Old Jan 17, 2008 | 04:15 AM
  #235
Mad_SB's Avatar
yes sir, i certainly did
Old Jan 21, 2008 | 08:58 PM
  #236
8UpUrV8's Avatar
Tephra, you're awesome man. V4.1 had the ICS going crazy, but V4.2 works great for further clarification, knock sensor maps have NOT been changed, correct?
Old Jan 21, 2008 | 10:28 PM
  #237
tephra's Avatar
no - that was just a definition problem.
Old Jan 22, 2008 | 11:22 AM
  #238
honki24's Avatar
Hey Tephra, got anything working for the 70008 ROM yet? I tested it a while back and again yesterday and like I said before, it makes the car unable to start plus the fan stays on as soon as the key goes to the on position.
-something I just thought of: I've got my EGR check disabled because I have a blockoff plate... could you have moved that code around so that when I changed that value I accidentally did something else?
Old Jan 22, 2008 | 02:06 PM
  #239
chmodlf's Avatar
94170008 working for me. I have about every mod going (tephra, mrfred boost mods, jdm map, etc.) except for your egr check...Must be something unique to your situation.
Old Jan 23, 2008 | 09:17 AM
  #240
honki24's Avatar
hmmm... maybe I'll try to start afresh w/o the egr thing... I guess I'll just throw a code for it. My fenders just came in so the coding might take a backburner for a while.... so excited to get this thing roadworthy again.
