PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Dec 20, 2007 | 08:21 PM
  #121
Jack_of_Trades's Avatar
My thinking is using the stock solenoid as a bypass solenoid which you can buy from alky kit manufacturers. Why buy something we might have already
Two scenario's, have it open fully to allow the wastegate to fully open when activated and drop boost pressure to 12psi
or
Have the boost map set for a predetermined amount (like 22psi for evoryder's setup). Under normal conditions, the boost goes thru the MBC, when activated, boost follows path of least resistance (boost soldenoid set to 22psi...or whater you set it to).
Just throwing ideas around.
Yeah, I'll keep the failsafe discussion out of here, I actually have one in the water/alky section but most ECUflash guys never browse that section. If anyone knows how to move these posts into a new thread, go for it
Old Dec 20, 2007 | 08:22 PM
  #122
tephra's Avatar
no I meant failsafe discussion pertaining to this patch!
Old Dec 20, 2007 | 08:25 PM
  #123
OHHHHH...good idea. You make it and I'll copy my stuff. People really tend to look at threads with your name under it,lol.
  #124
mfr122887's Avatar
Last one, sorry.
I currently have a AEM tru-boost and a FP actuator. So the failsafe will just cut the power to the aem solenoid, making the car run the base 18ish psi from the actuator. Makes the setup easier to setup.
Old Dec 20, 2007 | 08:39 PM
  #125
Thread for ALT MAP/alky kit failsafes HERE
Old Dec 21, 2007 | 05:34 AM
  #126
tephra's Avatar
oh man...
just my luck
Old Dec 21, 2007 | 05:42 AM
  #127
AutoXer's Avatar
Wow, that sucks Tephra. Hopefully it wasn't your fault. Is everyone OK?
There only apears to be three hex changes from 4.1 to 4.2. It would be much easer to change those three values in my altered 4.1 than to copy all my maps again. Would that cause any problems?
Old Dec 21, 2007 | 05:44 AM
  #128
honki24's Avatar
NOOOOOOOOOOOOO! Welcome to the club my man...
On the bright side, I can second the verification of V4.1 working. Seems to work flawlessly for me. I havent tried valet yet but nlts and alt maps work for sure.
Edit: AAH crap! What's 4.2 now?! I can't keep up!
Old Dec 21, 2007 | 06:36 AM
  #129
MR Turco's Avatar
OH MAN sorry to hear tephra! At least you are ok. It definitely looks like that can be fixed too. I hope everything works out!
Old Dec 21, 2007 | 07:19 AM
  #130
juyanith's Avatar
Crap! Sorry to see those pics tephra. I'll make sure to send you a donation to help and I hope you get back on the road quickly.
I just want to clarify the ICS coming on when flashed and what I think happened in my case. First, I tried flashing the 4.0 rom which immediately caused the ICS to come on, and the car wouldn't start. I flashed back to my previous ROM. Later, I flashed the 4.1 version and the ICS came on but went off when I hit the ICS button (manual or auto, I'm sure I tried both). Since then it's worked fine and hitting the manual switch causes it to stay on for the 500ms I have it set to.
Old Dec 21, 2007 | 07:25 AM
  #131
laakness's Avatar
Yep, I had the same thing and got it working last night. It's pretty sweet.
Old Dec 21, 2007 | 08:33 AM
  #132
cossie1's Avatar
Sorry to see that tephra thats not good news
Hope everyone was ok, and you get it all sorted asap.
Thought down under it was meant to be sunny this time of year ???
Old Dec 21, 2007 | 09:20 AM
  #133
honki24's Avatar
so... do I need 4.2? 4.1 seems to work fine for me.
Old Dec 21, 2007 | 09:39 AM
  #134
BarryC's Avatar
thats bad luck Dave,
you didnt deserve that, after all the good you do for the Evo community,
Hope everyone is ok,
Old Dec 21, 2007 | 10:05 AM
  #135
Evoryder's Avatar
awww man!!! WIth christmas now
