PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Dec 20, 2007 | 07:02 PM
  #106
Jack_of_Trades's Avatar
Originally Posted by mfr122887
How long does the change of map take after the button is pressed for the specified time? Could this alternate map be used as a failsafe: when the aquamist failsafe is activated it is wired to the ICS switch so the map would switch to a safe map for the non-meth boost levels. The time of holding the ICS button would have to be set close to zero so it would be almost instantaneous depending on how long it takes for the ecu to actually switch the maps. This could also be used in the case where you can have a totally non-meth map and then the flip of a switch, meth is active, boost is raised, and maps are changed accordingly. That would be a sick setup for the stock ECU.
Originally Posted by tephra
pretty much instant.
Yes that was something I was talking to one of the other guys about.
V5 or V6 will also bring in multiple boost control, and for the meth users out there (druggies?? :P) we are looking at wiring in some failsafe stuff, not sure how/what yet thou !!!
anyways let me get this problem fixed and a few more ROMID's up and then we can talk about V5 and beyond!
Think this might be me you were talking about Teph. Sorry it took me so long to find this thread, christmas has me very busy. I'm about to go do some ICS wiring testing at the ECU and switch to confirm full operations. Is the Auto switch a latching switch? Meaning, you hit it once and it holds a connection to ground, hit it again and it disconnects the connection (or switches to 12V+)?
Also, does this map switching technique completely mimic the map switching the stock ECU does when it switched to low octane maps to prevent engine damage, meaning it is that instant and happens during any driving condition which warrants the need to protect the engine?
I have PLENTY of alky injection failsafes that can trigger this SINGLE wire whenever there is a problem, just need to know how the ECU "see's" the signal from the ICS switch so I can have my circuit mimic it on its own when it sees the problem, and switch back when the problem is gone. Be back with info soon.
Old Dec 20, 2007 | 07:08 PM
  #107
AutoXer's Avatar
A couple of other things I noticed.
Any time the ICS is in auto, the Valet mode switching (via the TPS) doesnt work.
When your on the alt map with ICS in auto then try to switch the valet mode, it goes back to the standard map.
Did anyone else test these sequences? Maybe Im speaking too soon and 4.2 will fix this as well.
Old Dec 20, 2007 | 07:13 PM
  #108
tephra's Avatar
Just a quick answer to AutoXer - this was the original method of switching maps (before I put in "hold AutoICS" basically:
- car off
- ign on
- auto ics on (so ICS lamp is ON)
- hold TPS > 90% for altmap and < 90% but greater than 25% for normal maps
- turn of autoics whilst still holding the TPS
I have left that code in, because I think for NonICS equipped evo's it might still be used!
Old Dec 20, 2007 | 07:21 PM
  #109
AutoXer's Avatar
4) Auto Valet - just turn this option to1 and whenever you start the car (after taking the key out of the IGN for a little while) the car should automatically enable your valet/security RPM limiter.
"A little while" isn't a very technical term. That is, unless you predefine it... like this...
A little while = 1 sec;
Will the CEL still flash(rapidly) when you turn the ignition ON?
  #110
tephra's Avatar
guys ive updated 94170008 to v4.2 - can someone test it?
the CEL shouldn't flash for more than 60seconds (or whatever you set it to)
also the Spray shouldnt spray at all...
hopefully!
edit - a little while, yeah I dont know how long, I usually do it for like 10 seconds... basically if you take turn the IGN OFF and then ON again the ECU remembers where its "upto" in the code, and so my "first time init" stuff doesnt get run.
taking the key out for a "little while" basically resets the ECU code position...
kinda
Old Dec 20, 2007 | 07:57 PM
  #111
Tested the wires at the ICS switch.
Green/White - (+)12v for light INSIDE the actual ICS switch (activated when parking lights/headlights are turned on)
Black/Yellow - (-) Ground for light in switch
Blue - Manual trigger wire for ICS relay (connect this wire to (-) ground to activate ICS relay) only requires 3mA of current
Blue/White - Auto ICS wire (momentarily give this wire (-) ground once to turn on AUTO mode, must release and connect to (-) ground again to turn off AUTO mode) only requires 3mA of current
Black - (-) ground source for the MANUAL and AUTO triggers
Tephra, in the ROM code, is there a way to change the AUTO ICS trigger from momentary ground switching to:
ON = connected to (-) ground
OFF = no connection to (-) ground
I don't know how this setting is written in the code since I'm still a HUGE rookie at the disassembly process.
Old Dec 20, 2007 | 07:59 PM
  #112
tephra's Avatar
the parking lamp is different to the ICS lamp...
Old Dec 20, 2007 | 08:03 PM
  #113
mfr122887's Avatar
Should be fairly easy to implement the failsafe with this, right? The failsafe trigger wire just has to ground the ICS Blue/White wire and it will cause it to switch maps. However, unless there is some other way, the ICS switch would have to be manually pushed after the failsafe has deactivated to re-enable the primary maps.
Old Dec 20, 2007 | 08:06 PM
  #114
mfr122887's Avatar
This would be even better.
Sorry for the 2 posts, I saw the original post before you edited it.
Old Dec 20, 2007 | 08:08 PM
  #115
Also, my car already has a MBC when I bought it used but I want to know how the stock boost solenoid works. If you have no power to the solenoid, does it allow ALL boost pressure to reach the wastegate? When powered up, can you hook it up to completely cut off all boost from passing thru it (100% IDC I imagine) and can it handle being on constantly? Not the best thread for this but it pertains to some of the failsafes you guys with MBC's would really like to have with this map switching.
Old Dec 20, 2007 | 08:11 PM
  #116
tephra's Avatar
Just uploaded 94170015, might as well get this one into testing as well
With regards to MBC's I suspect that most ppl would/should be switching back to MrFreds direct boost control using the stock BCS??
Old Dec 20, 2007 | 08:14 PM
  #117
tephra's Avatar
Also can we move the failsafe discussion to a new thread? otherwise this will fill up real quick Jamie do you want to make it?
  #118
I know, this is the light INSIDE the actual switch which comes on when the parking lights or headlights are on.
Old Dec 20, 2007 | 08:15 PM
  #119
mfr122887's Avatar
Basically all you need is a MAC valve to allow all boost pressure to bypass the MBC and hit the wastegate. It would be cool to use all the stock hardware though.
Old Dec 20, 2007 | 08:16 PM
  #120
mfr122887's Avatar
I actually made one of these a while ago. I think we discussed what we are talking about the exact same things in this thread. If you want I can dig it up.
