PATCH: KNOCKCEL+NLTS+AltMap (V4)
Old Feb 8, 2008 | 09:50 AM
  #361
logic's Avatar
There's probably a long line of people looking to test 96940011. :-)
Old Feb 8, 2008 | 10:04 AM
  #362
fixem2's Avatar
Not just test but use!! Props to all involved!!
Old Feb 8, 2008 | 02:51 PM
  #363
tephra's Avatar
Cool thanks guys I will let you know when its out for your ROMID.
Old Feb 9, 2008 | 08:18 AM
  #364
Freddy302's Avatar
Hey I did a search on this thread.. (too many pages) But for the alternative maps.. Not sure if this was brought up.. But since it seems it can be so dangerous.. Can you set the stationary limit with it?
So say your Race gas/alchy/ or octane boost higher hp map you could have your stationary rev limit set to like 6000 RPM to confirm
And for your 93/91 oct or some no name pi$$ gas you can set the stationary limit to like 5000 rpm
This way it would be a lot easier to tell
Or do something like you did for the knock flashing the CEL fast and slow for High knock and low knock... Flash fast for HIGH hp map and Slow for Low HP Map?
just trying to be helpful.. not sure if any of this is possible I have no idea how to write any of this code stuff.. lol
-Freddy
Old Feb 9, 2008 | 09:24 AM
  #365
cossie1's Avatar
-Freddy
If you have AUTO ICS then the autoics lights flash on the dash when your using the alternate map.
If you have wired a manual switch with led (as I have) then you will have an led on, to show that your using the alternate map, and the led will be off if your on the standard map.
Old Feb 9, 2008 | 10:56 AM
  #366
Freddy302's Avatar
Sweet that is awesome!
Old Feb 11, 2008 | 07:04 PM
  #367
tephra's Avatar
UPDATE
Hey Guys - I need a couple of committed and thorough testers for 88590015 and 94170014.
Once they come back as positive then I will put up a new thread about V5.
Cheers
D.
Old Feb 11, 2008 | 11:22 PM
  #368
20psiMR's Avatar
Count me in tephra!
Click in my sig for email addy if u need it.
Old Feb 12, 2008 | 02:16 AM
  #369
spdracr's Avatar
will V5 be for all romid's or just those ones listed? and wat is changed in that version from the v4
Old Feb 12, 2008 | 03:07 AM
  #370
evo828's Avatar
Dave - for ROM like 96530006 where the only patch was the Knock Cell flash - will you be able to patch with the AltMap switching? No need for NLTS and all those other nice features - but the alt map + johnbanks live tuning would be very appreciated
Old Feb 12, 2008 | 07:11 AM
  #371
honki24's Avatar
I'm available for 94170014. (although I will use the ICS button for switching rather than the external switch)
flatlinemotorsports at hotmail point com
Originally Posted by tephra
UPDATE
Cheers
D.
Old Feb 12, 2008 | 10:42 AM
  #372
ciobing's Avatar
the NLTS too
Old Feb 12, 2008 | 08:10 PM
  #373
VT Mitsu's Avatar
oh well, just be slower at getting them out is all
the order will be:
88580014 (my rom :P)
90550001 (some UK 7 rom's - long ago promise )
94170014
88590015
96940011
etc etc..
To help me I probably won't do 94170008 or 88590013/14 - unless someone has a very specific reason that is
This is the rom I have (94170008) and have never had the p300 code, so never got the patch. So is that a very specific reason? I don't quite get the wink...
If I put the patch in my rom, will it work? (Only software change I have is a TTP mail-in flash).
(very new to all this :]
Old Feb 12, 2008 | 08:32 PM
  #374
VT Mitsu's Avatar
no problems, actually V5 (out soon) will have alt boost maps as well.. so time to dump those EBCs guys hehe
So will this work with the stock solenoid/hoses, or do I need a better one (to handle more pressure) to handle 23-ish psi? (I currently have the profec b spec2)
I know I have to do the research to see how to get the correct boost with the ECU (pill sizes, etc.) only thing is...I thought the psi's vary a bit, (shoot for 22, you end up with 21.5-23) or am I way off?
Tom
Old Feb 12, 2008 | 08:50 PM
  #375
tephra's Avatar
stock boost control only i'm afraid, so if you have an aftermarket ebc and want boost switching then you will need to get rid of it.
your cheapest/best bet would be to get a a 3port GM BCS and a JDM MAP and do MrFred's direct boost control...
re 08 vs 14 - thats still to be decided, but I can't see why you can upgrade to 14...
