need help with a/f at idel
Old Feb 14, 2008 | 07:52 PM
  #31
filter's Avatar
Originally Posted by Wicked E
Check your valve cover on the radiator side and see if its dirty with soot...
nope because i keep my car very very very clean like **** obssesive and ive never seen anything that would make me think an exhaust leak. but ill take his advice and put it on the lift while running and double check.
Old Feb 14, 2008 | 08:41 PM
  #32
C6C6CH3vo's Avatar
Or you can **** on the coils
Klatinn once recommended to get someone to place their hand over most of the tailpipe. If the AFR drops, then it's an exhuast leak. It runs lean because it draws air into the stream of gas thats picked up by the O2, build a little back pressure until it quits sucking by blocking the flow somewhat.
Old Feb 14, 2008 | 09:19 PM
  #33
Wicked E's Avatar
WTF is this supposed to mean?
If there was a leak at the o2 housing to downpipe connection, it tends to blow up to vent in the hood thus causing soot on the valve cover...
Old Feb 15, 2008 | 07:14 AM
  #34
filter's Avatar
then i dont have a leak there cause i dont get soot anywhere. but im still going to check today on the lift.
SudzRA
May 18, 2011 09:28 AM
wtf_is_a_evo
May 1, 2010 11:04 PM
5LEEPERISAH23I
Apr 18, 2010 06:48 PM
evokid511
Mar 26, 2009 08:45 AM
lancerMRguy
Jul 26, 2008 03:24 PM
