9653006v5 WORKS for 05 USDM (9694011)
You can download my XML file here http://homepage.mac.com/johnny_fergu...530006.xml.zip
As has been stated before Open Loop RPM doesn't look quite right but everything I use is OK.
John - I just took a look at the disasm - you can use elements=16 for the OpenLoop Loads ie
Code:
<table name="Open Loop Load # 1" address="3624"> <table name="RPM" address="6594" elements="16"/> </table> <table name="Open Loop Load # 2" address="363a"> <table name="RPM" address="6594" elements="16"/> </table> <table name="Open Loop Throttle Low Load" address="3656"> <table name="RPM" address="6594" elements="16"/> </table> <table name="Open Loop Throttle High Load" address="366c"> <table name="RPM" address="6594" elements="16"/> </table>
no, but you could rework the axis to get 7500 if you wanted.
however there probably isn't much point as 6000 == 7500 for the purpose of determining open/closed loop operation
So, from the sounds of it, the 96530006 does not support EGR, possibly other things. Once this is working, flashing a USDM 96940011 car will render the EGR system inoperable.
So, once we flash with the 9650006 ROM, we will be able to remove all the EGR parts because it will be unsupported by the ROM? (I hope so, I love less parts to fail! And for simplicity!) (And I live in SC, no vehicle inspections!)
Korekt?
Korekt?
It seems the 260 and USDM could be very similar cars as I believe they share the same cams, as well as having compatible ROM IDs, EGR but no SAS and the two O2 sensors.
All I need is about 30 minutes of uninterrupted time (yeah, right, good luck with that
) to transfer over my maps, and all the XML changes and tweaks I made, to Dave's v5 96530006, and I'll be running it (sans direct boost control). Map switching is what you might call a "compelling feature" for me.
