9653006v5 WORKS for 05 USDM (9694011)
I wonder if you can help me out. I'm in the process of installing an AEM water injection system into my Evo 8 260. The control box for the water injection has a built in MAP sensor that outputs 0 to 5 volts (.328v = 0psig, 5vdc = 38psig). Do you know if I can connect this to pin 73(MDP) in the ECU and log boost via MUT38? I assume I will need to work out a formula to convert voltage to PSI.
yes John thats all u need todo.
best thing to do is log raw map (ie 1-255) with the car off. then work out the formula for your altitude. then as long as its a linear relationship you should be fine
Tephra: I can't speak for Jason, but I've been running your 5.1 96530006 ROM for a hair over a month now in my commuter/grocery-getter, and it's been working out wonderfully. I think the only real problems left to solve that are unique to this ROM are:
- getting the immobilizer working again
- getting direct boost control working
