Tephra, can you make a mod to fix the VIII's p0300 issue?
Old Jul 31, 2008 | 01:51 PM
  #61
Slo_crx1's Avatar
Originally Posted by mfr122887
So you cut each value in half? And just to make sure I have the right definition, in table 1 they are all 0's right?
I pm'd you back...you can start by half, I added some timing back in in certain spots on mine and it hasn't adversely affected it. If I can get a few more people to test this on here and find that it works, I can throw together a little write-up on it with before and after tables and logged values and ask to have it stickied for future reference.
Old Jul 31, 2008 | 04:05 PM
  #62
Smogrunner's Avatar
Interesting. Switching from 94170008 to 94170015 cured the p0300 for me.
Old Jul 31, 2008 | 04:31 PM
  #63
Jack_of_Trades's Avatar
Well, that WAS Mitsu's intent after all so it should cure the majority of 94170008 users.
Old Sep 8, 2008 | 11:05 AM
  #64
Jazzie604's Avatar
Originally Posted by DCsleeper
Correct you are. The main change from the older series ROM 94170008 and series 94170014 was a change to one of the knock filter tables. I think it was the first or second table. Would have to go back and compare to be sure. When I had the flash performed by mitsubishi years ago the frequency of the error dramatically dropped. Later I flashed my ECU with the latest ROM in the series 94170015 to see if it would cure the problem for good. Unfortunatly it did not, but again lowered the frequency of occurance. Between 94170014 and 94170015 I was not able to see any changes in the tables currenlty viewable in ECUFlash.
From what I have read there seems to be several causes of this code. For me, I have to believe that it is due to a vibration caused by the trans. The reason I know this is I have tried everything else over the past 3 years to get rid of the annoying code (new injectors, ignition amplifier, reflashed ECU, and new exhaust hangers to prevent the exhaust from hitting anything).
I really wish that someone good with disassembling code would just find the p0300 error code and disable it. This is the only code I ever throw and it is incredibly annoying. For me, only occurs in low/med load conditions about 3500 rpms in 5th gear no boost (about 75 mph cruising).
Originally Posted by spdracr
between this and the phantom knock when pulling from a stop is driving me nuts lol
It appears that there may be 2 common causes for the P0300-idle issues that may have been adjusted by the reflash, and mechanical issues at cruising speed. I have recently had problems with the cruising issue. Sometimes the light comes on with no noticable cause, and sometimes I get a definite dead-hole stutter. Has anyone else had the light come on after the stutter, or is it always on before you feel a miss? I plan to do some datalogging for myself, but I want to find out if the miss is a result of the code changing engine performance, or if the code is the result of an actual miss.
Old Sep 8, 2008 | 02:51 PM
  #65
Slo_crx1's Avatar
Any time I ever had mine come on was right at the same time as the stutter, and then once the code was triggered it would stutter off and on until I reset the ecu.
Old Sep 18, 2008 | 10:42 PM
  #66
Brembo350z's Avatar
Bump, Tephra have you figured anything out about this?
Old Sep 26, 2008 | 02:06 AM
  #67
D-VO's Avatar
I'm also using 96940011 and am currently not enjoying the 0300 problem. Mine started when I lifted the head (too much boost, oops). Since then I had the engine rebuilt twice and I'm sill having the same issue.
Old Oct 30, 2008 | 10:04 AM
  #68
jmelocik's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=377898
Check this out for all you guys with P0300 problems.
Josh
Old Nov 1, 2008 | 11:17 PM
  #69
D-VO's Avatar
Thanks for the heads up Josh.
Evolcomk
16
May 30, 2015 11:33 AM
Slo_crx1
Jul 20, 2008 05:46 PM
djulian21@juno.
Feb 9, 2008 07:16 PM
MYFIRSTEVO
12
Oct 18, 2005 05:12 PM
KazzEvo8
13
Nov 30, 2004 09:10 PM
