fix for p0300?
Old Feb 2, 2008 | 02:30 AM
djulian21@juno.'s Avatar
fix for p0300?
i've been searching the forum, but i can't seem to find a fix for p0300 ( random misfire). is there a fix, and if so, would someone please post.
Old Feb 2, 2008 | 03:48 AM
yokomo's Avatar
I think my car had that problem before I bought it. There's a sticker under my hood telling me that the car had been reflashed by Mits, I guess to solve that problem. If I'm wrong....please someone correct me.
Old Feb 2, 2008 | 10:20 AM
dsm_mikey's Avatar
good luck, there are a million threads on this. My 03 had this and it is really, really, really annoying. Pick up a C Reader off rom ebay and plug it into your OBII port-this helps a lot. Go to VISHNU.com and he sells them there as well.
There is a recall from Mitsu on this, I believe. If your car is under warranty or stock, talk to them.
Good luck it is a horrible problem. It made me trade my 8 for a 9.
Old Feb 2, 2008 | 10:23 AM
dsm_mikey's Avatar
I forgot to mention, my problem became much worse after installing an ACT Lightened Flywheel and Exedy clutch. I do not know why.
Old Feb 2, 2008 | 11:06 AM
ODUB's Avatar
sorry to burst your bubble, but the 9's have this problem too. mine just started it about 5k miles ago. now it happens about once a week. light comes on, stays on for a day or so, goes off. no idea why.
Old Feb 2, 2008 | 07:40 PM
BBS's Avatar
BBS
You need to diagnose why youre getting a random misfire. There isn't one single solution for any given cel code. Try to find a friend or a friend of a friend with a solus and vantage.
Old Feb 3, 2008 | 12:56 PM
kkarim's Avatar
i believe the mitsu had a recall on this. they reflashed the ecus.
if you go to aktivematrix's download section, you can find a rom that the dealer flashed in a customer's car to fix the p0300 error, then with ecuflash and a tactrix cable, you can reflash your ecu yourself to fix it.
don't forget to copy your fuel/timing/boost maps if your ecu has already been reflashed.
Old Feb 3, 2008 | 01:08 PM
evolution666's Avatar
If its any help I took my evo to the stealership to get reflashed. The reflash erases your flash if you have one. I simply took my car to ams afterwards and got reflashed. No problems since. GOOD luck.
Old Feb 3, 2008 | 01:10 PM
TURBevO8's Avatar
Dealer flash. Went from getting the CEL once a week to once a year after the dealer reflash.
Old Feb 3, 2008 | 05:05 PM
evoterp's Avatar
hope this sheds some light on the problem....
https://www.evolutionm.net/forums/sh...d.php?t=321822
Old Feb 5, 2008 | 12:08 PM
EvO9 PiPER's Avatar
SO been to the dealer and i they said it should have fixed it but, on the way back home same code!!! i cant find a way to get it off but to drive the car like a 80 year old!!! any another ideas??
Old Feb 9, 2008 | 07:16 PM
03blkevo's Avatar
Okay I have also received a P0300 error on my 03 evo and i was wondering if there is a universal fix or a rom i can DL that allows me to rid the ecu of p0300 errors
dxlykos0131
May 7, 2014 06:15 AM
afmafia
59
Jan 30, 2009 12:25 AM
tequila083
Apr 6, 2006 11:30 AM
MYFIRSTEVO
12
Oct 18, 2005 05:12 PM
KazzEvo8
13
Nov 30, 2004 09:10 PM
