P0300 code after installation of new trans.
Old May 4, 2014 | 04:27 PM
dxlykos0131's Avatar
After getting my new trans installed every time I cruise on the highway I throw the p0300 code. Any idea how to fix this or what the problem might be?
Old May 4, 2014 | 04:45 PM
ak47po's Avatar
Random misfire code, not trans problem.You got cams?
Old May 4, 2014 | 04:52 PM
Nope, only mods are VTA bov and exhaust
Old May 4, 2014 | 05:06 PM
Ecr33's Avatar
Are u still running a maf? Or u on speed density?
Old May 4, 2014 | 05:11 PM
Yes still running a maf
Old May 4, 2014 | 05:21 PM
Ecr33's Avatar
Ok thats most likely ur problem as running a vta blow off on a maf causes it to run rich in between shift or when u let off the gas. You need to switch to speed density to run vta blow valve properly!! Most likely thats what is causing your misfires.
Old May 4, 2014 | 05:42 PM
Ah ok. Thanks man
Old May 4, 2014 | 05:55 PM
slowsrt4:('s Avatar
you can either convert to speed density (will need a tune for this) or you can get a bov that recirculates. what bov do you currently have?
Old May 4, 2014 | 06:26 PM
Blitz, the previous owner had the car street tuned for the VTA though. Put an Evo 9 bov on and the car ran like crap.
Old May 6, 2014 | 07:49 AM
jrainwater's Avatar
I didn't read the whole thread but if someone hasn't mentioned it yet you can just turn off the p0300 code with ecuflash. I don't remember the periphery bit at the moment but its marked as such "P0300". Just change it to 0 instead of 1 and the code will never come back again.
Old May 7, 2014 | 05:53 AM
Atrophical's Avatar
Like I've told you previously Deme, it's the VTA. The car isn't ment to run like that without running speed density. Switch it back and everything tuned correctly with the new LICP and intake you just put on.
Not worth speed density at this present time especially with basic bolt-on's and stock turbo.
Do it right the first time and fix the imperfections from previous owner.
Old May 7, 2014 | 06:15 AM
jrainwater's Avatar
My buddy had an 04 VIII that threw the P0300 constantly with ZERO mods on the car(bone stock). I'm sorry but you can't say with 100% certainty its the bov. I have an 06 IX with a TialQ and I vta on maf and have never once got the P0300 code ever. Granted I tuned my fuel and timing maps accordingly but he could, like I previously stated, just turn the code off in the ecu.
cognizio
Outlander Sport
May 28, 2024 06:38 PM
Welcome2GoodBur
Mar 17, 2017 08:17 PM
mrfred
Apr 9, 2015 11:20 AM
vassago
Sep 26, 2009 07:05 AM
Muramasa
Mar 8, 2004 03:21 PM
