Patch how-to: manifold air temperature logging
Old Aug 26, 2009 | 08:58 PM
  #331
mrfred's Avatar
Originally Posted by MR Turco
working! I know you are busy, any word on applying this to V7?
I might be able to do it during my trip home on Friday. Depends on whether I can finish up a little task I'm doing for an Evo VI owner.
Old Aug 27, 2009 | 05:07 AM
  #332
MR Turco's Avatar
much appreciated!
Old Aug 31, 2009 | 03:01 PM
  #333
Wheatley's Avatar
Does anyone know what color the wire leading into pin 77 on the evo 8s is? Is it blue with white or a light solid wire?
Old Sep 6, 2009 | 04:29 PM
  #334
Vigman's Avatar
Hi guys, I am sorry if this has been asked already but could it be possible to use this for EGT instead IAT????? Or may be both with a small switch...?!?!
Any opinion?
Cheers.
Old Sep 8, 2009 | 08:38 AM
  #335
Vigman's Avatar
Any opinion?
Cheers.
Come on guys!!!
I have read all the thread and nothing... Aren't you interested in EGT???
I think it will be just a question of rescaling table...
Here is the part I have in mind...
Hope someone else believe it's a good idea!!
Cheers,
C>
Old Sep 8, 2009 | 11:05 AM
  #336
mrfred's Avatar
Any opinion?
Cheers.
EGT is measured using a type K thermocouple which produces a millivolt signal. The signal is not compatible with the temperature signal inputs on the ECU, so it cannot be used in place of an IAT sensor signal. However if a standalone TC readout with an analog output is used, then the analog output can be fed into one of the 0-5V ADC inputs on the ECU.
Old Sep 8, 2009 | 02:26 PM
  #337
Vigman's Avatar
Thanx man! Let me work on a small amp to get a 0-5V signal from the K Thermocouple!!!
Cheers,
C>
Old Sep 8, 2009 | 02:48 PM
  #338
Vigman's Avatar
Here you are...
I'll try this soon!
Cheers,
C>
Old Sep 12, 2009 | 11:16 AM
  #339
lan_evo_mr9's Avatar
I'm trying to find the correct IAT from Ballenger Motorsports and the part number isn't registering. It looks like the correct sensor is the one on the bottom of the page, but I'm not sure and I don't want to buy the wrong one. Any help would be appreciated.
Edit: Nevermind, figured it out.
Old Sep 16, 2009 | 12:13 AM
  #340
Danieln's Avatar
Installing the IAT sensor into the intake manifold it will give false readings from heat soak from the engine or not?
It is best to install the sensor in the intercooler pipe just before the air enters the throttle body or to add it into the intake manifold?
I have allready the intake prepared for the IAT sensor (JDM version)
Old Sep 16, 2009 | 01:32 AM
  #341
rolly1818's Avatar
Registered User
not sure where is best, i have it on my intake manifold - MAT sensor that came with the JDM IX. i rive lots of long trips 2+ hours and no difference.
we dont have major temp swings here though.
Old Sep 16, 2009 | 02:20 AM
  #342
Danieln's Avatar
So installing this into intake will not cause some big wrong readings right?
I have the same manifold like you
Old Sep 16, 2009 | 03:47 PM
  #343
rolly1818's Avatar
Registered User
i am no professional
but i have had no problems yet neither have any of the other JDM IXs. i would mount it there no worries.
Old Sep 18, 2009 | 09:50 AM
  #344
Danieln's Avatar
I already have a sensor on my intake manifold but for GM IAT I need a bigger NPT bung.
I`m still looking for the wires for this 25972 sensor.
Old Oct 7, 2009 | 02:06 PM
  #345
evilevo2006's Avatar
Updates
Add the following entry to your EvoScan "Data.xml" file:
----- (don't add the "-----")
<DataListItem DataLog="Y" Color="" Display="Manifold Air Temp" LogReference="MAT" RequestID="09" Eval="1.8*x-40" Unit="deg F" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-40" GaugeMax="300" ChartMin="-40" ChartMax="300" ScalingFactor="1" Notes=""/>
Save the Data.xml file. That's it for the software modifications.
do we add this in right before the </EvoScanDataLogger>
example
