Patch how-to: manifold air temperature logging
Old Oct 18, 2008 | 04:18 PM
  #91
Jack_of_Trades's Avatar
Originally Posted by gear head
How might a guy persuade you?.....within reason of course
dont go there....my butt's still hurting from the last time he helped me out
Old Oct 19, 2008 | 06:07 AM
  #92
gear head's Avatar
^LOL, that's funny. I hope you had a quick recovery.
Old Oct 19, 2008 | 09:23 AM
  #93
mrfred's Avatar
Money is always good. :-) I need to buy a stock (used) airbox to tinker with some improved airflow options. But I couldn't start on porting the MAT patch for a few weeks because I've got to put a little time into updating the Evo 9 XML files and help a bit with the Evo X XMLs for ECUFlash.
Old Oct 19, 2008 | 09:30 AM
  #94
Oh, I'll be sending a donation your way once I have my Zeitronix MAP sensor working as a replacement for the JDM map and also the use of the IAT on my 94170015. You can be certain of that
Old Oct 19, 2008 | 05:48 PM
  #95
tephra's Avatar
Why don't you use the existing ECU pin for IAT sensor? (Rather than the fuel temp sensor)
Edit - Just looked at the ECU wiring diagram. Interestingly pin 96 is already assigned to "air intake temperature"
Old Oct 19, 2008 | 05:54 PM
  #96
dryad001's Avatar
If you want to pay for shipping Ill send you my air box free of charge.
Old Oct 19, 2008 | 05:59 PM
  #97
tephra's Avatar
Also:
http://www.bmotorsports.com/shop/pro...roducts_id/400
Says it only has a sealing pressure of 200kpa.. Which is only 14.5psi (29-atmo)
Old Oct 19, 2008 | 06:15 PM
  #98
Originally Posted by tephra
Also:
Hmm, since people have been using these on turbo'd cars forever I wonder how much it really would leak under higher boost levels. All I know is I'm dying to try mine lol.
Old Oct 19, 2008 | 06:21 PM
  #99
gear head's Avatar
Cool, works for me
Old Oct 19, 2008 | 06:25 PM
  #100
tephra's Avatar
I can't order from BMS - anyone feel like ordering me the IAT + pigtail (total of about $22 USD) and ship it to me?
I will pay of course
Old Oct 19, 2008 | 06:34 PM
  #101
MR Turco's Avatar
Tephra, i orderd this one:
http://www.rs-autosport.net/catalog/...roducts_id=216
since it came with the pigtail i considered it a better deal. I can send you mine and order a new one, think of it as a donation
Pm me your address if you are interested.
  #102
Try RS autosports
EDIT: wow Turco...beat me to it! lol
Old Oct 19, 2008 | 06:44 PM
  #103
tephra's Avatar
wow - cool man thanks
My only concern is the "sealing pressure" as high-lighted above.
Old Oct 19, 2008 | 06:48 PM
  #104
MR Turco's Avatar
Seems like Mrfred is running it without issue. I am not sure why it wouldn't seal above 14.5psi
Old Oct 19, 2008 | 06:56 PM
  #105
tephra's Avatar
yeah its probably fine - but i get paranoid about boost leaks
