Looking for more maps, 80700010 Def
Old Feb 27, 2011 | 01:58 AM
  #256
tephra's Avatar
Just copy/paste it into you 80700010.xml in your ecuflash directory...
Should work..
Old Feb 27, 2011 | 02:55 AM
  #257
foxbat's Avatar
Originally Posted by tephra
I just looked this up for you guys, unlike other CT9A's there are two tables:
Code:
<table name="Boost Limit #1" category="Turbo" address="3a48" type="2D" scaling="LoadBoost">
    <table name="RPM" address="6266" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Boost Limit #2" category="Turbo" address="3a58" type="2D" scaling="LoadBoost">
</table>
This is great I shall try this today.
Could you investigate address: 173e (1d table) which should be the 'timing retard limit' ?
Finally, the GT-A could be tuned properly
Thanks Tephra
Old Feb 27, 2011 | 01:39 PM
  #258
foxbat's Avatar
Just tested the above addresses & they worked like a charm :} GTA has 22psi of boost now!
Old Feb 27, 2011 | 01:45 PM
  #259
nads1978's Avatar
You want to upload your xml so I can compare to mine?
File Type: zip
Old Mar 3, 2011 | 04:46 PM
  #260
midegade's Avatar
Hi nads1978,
I have changed my auto tranny (same as the GT-A) Airtrek to 5-sp manual and re-using the stock ecu.
My tuner is good with the Hallman mbc and prefers to tune with it.
However, I've read here that you can tweek for wider, more consistent power band by replacing the oem solenoid with units from (Grimmspeed, Perrin) and an EvoX 3-bar map sensor and reflash.
My tuner states that this is all well and good but the base maps would have to be setup and this could take a long time.
Would you have any base maps that could help me/him for ecu controlled boost.
I'm using an evo8 Turbo w/ 10.5 hotside, walbro 255, megan bolt-ons, hks 272's and 3" exhaust.
Old Mar 3, 2011 | 11:26 PM
  #261
nads1978's Avatar
Originally Posted by midegade
Hi nads1978,
I'm using an Apexi boost controller, not the ECU. So I'm sorry - I cant help.
When your tranny was changed to manual, do you know how the speedometer was wired in(GTA ECU has no direct input like the manual ECU)? Also do you have a diagram of the ECU pin-outs for your Airtrek?
Old Mar 4, 2011 | 07:11 AM
  #262
midegade's Avatar
I'm not sure. Gotta ask the technician, but he basically used the input from the speed sensor in the 5-sp transmission. Originally, the speedometer read from two inputs from the auto tranny shaft.
I don't have the pin-outs, sorry.
But I'll ask my technician if he could do a trace.
I think he has the ability but most times he does not have much time.
Old Mar 4, 2011 | 09:46 AM
  #263
nads1978's Avatar
Yes, the same as the GTA - the 2 shafts on the auto box go to the ECU, then the ECU outputs to speedometer. On the manual cars, the signal goes from transmission, to ECU, and "forks" on up to the speedometer too.
If he has any pin-outs that would be a massive help for me, I'm trying to complete the GTA pinout and would be good to compare them.
Old Mar 4, 2011 | 12:41 PM
  #264
foxbat's Avatar
Now, since we have some decent definitions to tune the GT-A, has anybody attempted to play with the shifting tables (shift pressure & time)? What would be a good approach to improve the performance of the tranny using those tables?
Old Mar 5, 2011 | 07:37 PM
  #265
midegade's Avatar
Just need to catch him on the right day and at the right time.
I'll update you for sure.
Old Mar 9, 2011 | 11:06 AM
  #266
wreckleford's Avatar
Does anyone know the 2-byte load address for 89970017 (2005 Airtrek)? I am willing to donate some money if someone is willing to take the time to find it. Thanks.
Old Mar 17, 2011 | 01:14 PM
  #267
nads1978's Avatar
Originally Posted by Mattjin;
I cant even find an ECU pinout for the GT-A, even with a trusted local Mitsu dealer trying to track me one down in Japan through the manufacturer.
Get any joy with that?
Old Mar 21, 2011 | 03:32 PM
  #268
midegade's Avatar
Hi,
Spoke to the technician over the weekend and he said he took the cables that go from the the tranny shafts and wired them directly to the speedometer. He bypassed the auto ecu entirely.
Old Mar 22, 2011 | 12:11 AM
  #269
nads1978's Avatar
Hi,
Okay thanks, I think you must have the older INVECS II box, it had a speedo output like the manuals does, the same as some of the Galant VR4s over here.
Old Mar 22, 2011 | 09:37 AM
  #270
midegade's Avatar
That's correct.
Had the InvecsII, now 5 on the flooor, RS style.
