Looking for more maps, 80700010 Def
Old Jul 3, 2011 | 11:23 PM
  #286
GregM's Avatar
Originally Posted by nads1978
Plus, can get some Tephra mods
Want to share your xml? Mine is in my signature.
The pin out was your one that I had.
Hmm, I'll email you.
Old Jul 4, 2011 | 06:04 PM
  #287
wreckleford's Avatar
Originally Posted by GregM
Boost Limits
<table name="Boost Limit N,1,2 Gear" category="Turbo" address="37fe" type="2D" level="4" scaling="LoadBoost">
<table name="Engine Speed" address="684c" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Boost Limit 3,4,5 Gear" category="Turbo" address="380e" type="2D" level="4" scaling="LoadBoost">
</table>
<table name="Boost Limit" category="Turbo" address="381e" type="2D" scaling="LoadBoost">
<table name="RPM" address="684c" type="Y Axis" elements="9" scaling="RPM"/>
</table>
Thanks Greg.
Old Jul 4, 2011 | 06:23 PM
  #288
Boost Limits
</table>
</table>
</table>
Greg, what does the 3rd boost limit do. I thought there were only two.
Old Jul 5, 2011 | 07:04 AM
  #289
GregM's Avatar
I'm not sure, I only altered the first 2 and left the 3rd and that seemed to work for me.
Old Jul 11, 2011 | 06:36 PM
  #290
gunzo's Avatar
3rd one is not a boost limit .. there's no '3rd boost limit'
To do the a dual fuel / ignition / boost map on the GTA is easier than the manual
The rom itself already has 2 maps of everything .. I just changed the gear trigger to something else and you get your switchable maps..
Old Jul 11, 2011 | 06:43 PM
  #291
GregM's Avatar
Hmm wonder what it is. I have a load of maps which are defined, but no idea what they are for. I have no idea on that side of things, basically swapped xml with people trying to build a more complete xml.
If anyone wants to have a look at what I have and my rom and try to figure out some of it, I'd really appreciate it.
Old Oct 1, 2011 | 11:19 AM
  #292
JohnBradley's Avatar
It seems to me in looking at the shift maps that the values vs tps are KM? I ran a sim on the base lancer stuff and came up with the following (based on a 185-70-14 tire)-
Stock rev limit - 6203
final drive - 4.04
1st - 2.83 (max speed 63 km/h)
2nd - 1.53 (max speed 116 km/h)
3rd - 1.00 (max speed 178 km/h)
4th - 0.710 (max speed 255 km/h, no shifting into 5th on a 4 spd)
Here is are the shift tables to compare to my math-
One side is going to be upshift vs speed and the other is downshift. This is just a theory of mine as I dont have a car to test. Anyone had an opportunity to play with this and see what it does? It doesnt pan out exactly the same but it is close enough to not ignore. It might just be a case of making the math fit the data which is also very possible.
Aaron
Old Oct 1, 2011 | 11:58 AM
  #293
GregM's Avatar
I'm happy to try it out on my Airtrek if you can send me the xml. I have your left column defined as TPS volts for my xml. I have altered my up shift pressure from 4.06 volts and up and it can definitely be felt.
<table name="1st to 2nd shift pressure" category="AT" address="418d2" type="2D" level="1" scaling="duty">
<table name="throttle" address="41882" type="X Axis" elements="16" scaling="Volts16"/>
</table>
<table name="2nd to 3rd shift pressure" category="AT" address="418e8" type="2D" level="1" scaling="duty">
</table>
<table name="3rd to 4th shift pressure" category="AT" address="418fe" type="2D" level="1" scaling="duty">
</table>
<table name="4th to 5th shift pressure" category="AT" address="41914" type="2D" level="1" scaling="duty">
</table>
Old Oct 1, 2011 | 12:26 PM
  #294
Greg,
you seem to have a second set of upshift pressure tables than I have defined via Roadspike's XML for the lancer. I reference the 41e6a rather than 41882. Here are his shiftmap definitions-
<table name="Shift Map 1" category="Shift Maps 1" address="419f6" type="2D" level="1" scaling="uint8">
<table name="load" address="41174" type="Y Axis" elements="32" scaling="ThrottleVoltage16"/>
</table>
<table name="Shift Map 2" category="Shift Maps 1" address="41a42" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 1" address="41a8e" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 1" address="41ada" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 1" address="41c0a" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 1" address="41bbe" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 1" address="41b72" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 1" address="41b26" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5 Condition 2" category="Shift Maps 1" address="48130" type="1D" scaling="uint8"/>
<table name="Shift Map 6 Condition 2" category="Shift Maps 1" address="48134" type="1D" scaling="uint8"/>
<table name="Shift Map 7 Condition 2" category="Shift Maps 1" address="48138" type="1D" scaling="uint8"/>
<table name="Shift Map 8 Condition 2" category="Shift Maps 1" address="4813c" type="1D" scaling="uint8"/>
<table name="Shift Map 1" category="Shift Maps 2" address="41a1c" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 2" category="Shift Maps 2" address="41a68" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 2" address="41ab4" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 2" address="41b00" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 2" address="41c30" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 2" address="41be4" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 2" address="41b98" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 2" address="41b4c" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 1" category="Shift Maps 3" address="428a0" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 2" category="Shift Maps 3" address="428ec" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 3" address="42938" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 3" address="42984" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 3" address="42ab4" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 3" address="42a68" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 3" address="42a1c" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 3" address="429d0" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 1" category="Shift Maps 4" address="428c6" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 2" category="Shift Maps 4" address="42912" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 3" category="Shift Maps 4" address="4295e" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 4" category="Shift Maps 4" address="429aa" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 5" category="Shift Maps 4" address="42ada" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 6" category="Shift Maps 4" address="42a8e" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 7" category="Shift Maps 4" address="42a42" type="2D" level="1" scaling="uint8">
</table>
<table name="Shift Map 8" category="Shift Maps 4" address="429f6" type="2D" level="1" scaling="uint8">
</table>
Old Oct 1, 2011 | 12:29 PM
  #295
Here are the shift pressure maps I am seeing-
<table name="1st to 2nd shift pressure" category="Automatic Transmission" address="418d2" type="2D" level="1" scaling="Percent255">
<table name="load" address="41e6a" type="X Axis" elements="16" scaling="VoltsADC1023"/>
</table>
<table name="2nd to 3rd shift pressure" category="Automatic Transmission" address="418e8" type="2D" level="1" scaling="Percent255">
</table>
<table name="3rd to 4th shift pressure" category="Automatic Transmission" address="418fe" type="2D" level="1" scaling="Percent255">
</table>
<scaling name="Percent255" units="%" toexpr="100*x/255" frexpr="255*x/100" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
Old Oct 1, 2011 | 12:31 PM
  #296
Also does anyone have the torque converter solenoid map at 417eb defined? I am looking at it and seeing something like 53% max...I am sure I have something off somewhere.
Thanks
aaron
Old Oct 1, 2011 | 12:32 PM
  #297
GregM's Avatar
I've added those shift maps to my xml, but only get the right column, I'll get it sorted.
Old Oct 1, 2011 | 12:34 PM
  #298
Might be I forgot some scaling information? Everything appears to be the same from the GTA to the base lancer for auto control.
Old Oct 1, 2011 | 12:36 PM
  #299
GregM's Avatar
My scaling is Volts16 instead of throttlevoltage 16, so am just changing them now. Looks good so far, should be able to give it a go for you in a few hours.
  #300
<scaling name="ThrottleVoltage16" units="V" toexpr="x*5/256" frexpr="x*256/5" format="%.2f" min="0" max="5" inc="0.05" storagetype="uint16" endian="big"/>
cool beans
