EcuFlash and Vista
Old Jun 7, 2008 | 02:43 PM
  #31
dryad001's Avatar
Well I just picked up a new laptop with Vista. Seemed like Ecuflash DL great and no hiccups on the install. Same went for Evoscan 2.3 (yes 2.3 is out in beta format) Once this tornado warning passes Ill head to the car and see if everything connects.
FYI, Im using Home premium.
Old Jun 19, 2008 | 02:54 PM
  #32
slim_jim989's Avatar
I finally got the ecuflash v1.35 working im running the 64bit vista ultimate but i cant get the evoscan to work right its always giving me an error code when i first start evoscan v2.3
Old Jul 3, 2008 | 10:41 AM
  #33
autoxer_minh's Avatar
I'm running 64bit Vista also and ran into a similar problem with Evoscan. Here's how I got things working. I changed the properties for the executable to Run as Administrator. The first time I ran Evoscan after this change, it asked me for the registration code and everything's been fine since. I don't recall if I had to do the same for ECUFlash, but I don't think I did. Hope this helps.
Old Jul 11, 2008 | 12:48 AM
  #34
red evo8's Avatar
i am having the problem with vista right now not having the driver installed
Old Jul 11, 2008 | 08:53 PM
  #35
~BoOsTeR~'s Avatar
use 1.34
I had the same exact problem with 1.35 - Vista Home Premium - Duo Core, rolled back to 1.34 and it worked like a charm.
Old Jul 11, 2008 | 11:19 PM
  #36
markymark1082's Avatar
Originally Posted by ~BoOsTeR~
use 1.34
+1
Old Jul 13, 2008 | 12:14 PM
  #37
red evo8's Avatar
I checked the thread on ecuflash versions but no link to 1.34 was provided any help?
Old Jul 13, 2008 | 06:49 PM
  #38
~BoOsTeR~'s Avatar
Here you go man, 7 days or 100 DL's, whichever is first.
https://rcpt.yousendit.com/588915197...e73a427fd1ddf3
Old Jul 14, 2008 | 12:09 AM
  #39
funks's Avatar
Did you uninstall the v1.34 tactrix cable driver, then installed v1.35 along with the V1.35 tactrix driver? There were some driver changes.
Old Jul 15, 2008 | 10:33 PM
  #40
red evo8's Avatar
ty good sir!
canclled
Nov 8, 2014 07:11 AM
def1
Feb 14, 2013 09:37 PM
17579EVO9MR
May 30, 2012 08:00 PM
brenner
Jan 27, 2010 12:25 PM
Nissan2Evo
Apr 26, 2009 08:59 AM
