Direct PSI based boost control on ROM ID 96420008
Old May 20, 2008 | 11:14 AM
racer135's Avatar
Is anyone using Direct PSI based boost control on an EVO 8 with ROM ID: 96420008. I know the address on the instructions post but what I am asking is if any one have successfully used direct boost control an EVO 8 with ROM ID: 96420008 and what address you are using for the Variable for boost control. I am trying but so far I have not being able to log Boost Error, it always shows as -3.087 and the WGDC correction is always 0.
Old May 23, 2008 | 11:29 AM
racer135's Avatar
Am I the only one trying to do direct PSI based boost control on ROM ID 96420008? Have anyone tried this before?
Old May 23, 2008 | 09:47 PM
mrfred's Avatar
Found the problem. He had not quite followed all the instructions in my how-to. :-))
Old May 24, 2008 | 07:59 AM
racer135's Avatar
I am using ECU Flash 1.34 so I needed to change some of the definitions on the instructions from:
endian="little" to endian="big"
My boost adder ended up being 3706 psi, no wonder why I was always under boost on my boost correction tables. The boost error correction table was also mess up. All the boost entries of 2 bytes (psia16; storagetype="uint16") were messed up due to that. I wil test again today. I am sure this will fix the problem. THanks for the help
Orlando
mrfred
Dec 15, 2022 11:13 AM
mrfred
Feb 26, 2022 06:16 PM
mrfred
Sep 17, 2017 06:11 AM
EVO8speed
Dec 1, 2008 07:05 PM
Dero
Sep 14, 2006 01:35 PM
