2byte to 1byte load mod
Old Oct 24, 2009 | 01:56 PM
  #61
ohhgyeahfasho's Avatar
Originally Posted by kaj
so now i just log "ecu load" instead of "2byte load mod"?
log 1byte load on EvoScan, add this on your data.xml for EvoScan, or use EvoScan 2.6.
Originally Posted by tephra
no - forget 2byte load or load 11bit4.
Code:
<DataListItem DataLog="Y" Color="" Display="Load 1Byte" LogReference="Load" RequestID="41" Eval="1.2*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" />
Old Nov 4, 2009 | 03:56 PM
  #62
Evo_Jay's Avatar
Okay I gotta question.
If I wanted to log 1 byte load on a 96420008 ROM, how would I got about doing it?
I am already loggin the 2byte corrected that everyone used to log.
I already have 1 byte load ready to log in EVOscan.
Just need to know what to do to the ROM to make this work.
Old Nov 4, 2009 | 03:59 PM
  #63
tephra's Avatar
You need to use a V5.10 or greater ROM.
I think I did a 964200XX stream of V5.10
Old Nov 4, 2009 | 04:01 PM
  #64
Evo_Jay's Avatar
No chance I can mod 96420008?
Also I left you a vistor message on your profile, let me know.
Old Nov 4, 2009 | 04:04 PM
  #65
tephra's Avatar
not easily... sorry dude.
Old Nov 4, 2009 | 04:14 PM
  #66
Evo_Jay's Avatar
Its okay...especially if you make a EVO VIII USDM V7 ROM like were discussing in the V7 thread.
Old Nov 4, 2009 | 04:21 PM
  #67
donour's Avatar
What's wrong with 9653006?
d
Old Nov 4, 2009 | 04:27 PM
  #68
Evo_Jay's Avatar
d
Many things.
Old Nov 20, 2009 | 03:30 AM
  #69
Boosted GP's Avatar
Hi all,
Ok, now i am very confused.
i am on the v7 tephra 88850715 rom and found that by 2 byte load is a good 10% above the load the ecu is using (verified from my timing logs) and seanv has the same issue (who posted in the v7 thread)
sean got 1byte load working (raw) and it seems to be correct according to the timing numbers now.
But:
what does the ecu use for 88850715 rom for output of timing and afr. does it use raw load+baro+temp or just raw load?
my MUT table are set at: MUT00 = 6b42 and MUT 01 = 6b43
from what i have read these are logging raw 2byte load. i want to either log corrected (temp+baro) 2byte or 1byte load.
i have changed evoscan to read 1byte, so if i can get the correct mut address for it to read correctly.
also is the mut table purely for logging or does the ecu use it for output . i.e. if we change altitude, will the ecu compesate for it if i am using the raw 1byte mut numbers?
I live at 5500ft, so compensated would be best (I assume)
Mike
if i go 1byte it seems the address needs to be what? 6b4a and 6b4b (assuming that the 898a/b for the 9653 rom
Old Nov 20, 2009 | 07:01 AM
  #70
rolly1818's Avatar
Registered User
use tephra's rom for 1 byte i believe V7 should have it built in right?
Old Nov 20, 2009 | 08:52 AM
  #71
Boosted GP's Avatar
I was going to to try that tomorrow, but have read 1byte load cannot run compensation for baro and temp..
will it not give a similar reading to 2byte if uncompensated, hence why i thought of staying with 2byte to get compensation working as our high altitude has an effect.
on the 8859015 rom what mut00/01 numbers do i enter for 1byte load?
thanks
Mike
Old Nov 21, 2009 | 11:20 AM
  #72
rolly1818's Avatar
Registered User
^^ use a tephra rom for 8859 it has 1 byte built in already. just flash it and log.
u may need to add it in evoscan as tephra said.
roni4g63
Nov 14, 2015 11:45 AM
kartectuning
Jun 14, 2012 08:01 PM
Seijuro
Mar 20, 2010 11:53 AM
andrewzaragoza
Feb 18, 2008 06:28 PM
NIevo
Sep 21, 2007 07:11 PM
