TephraMOD V5.8 - testing help required
Old Jun 16, 2008 | 08:53 PM
  #31
fostytou's Avatar
EvoM Community Team
I was just speaking in general, still running 5.0 so far
I'm slightly concerned about the map averaging related to overshoot... but hopefully lowering to update intervals of 1 will help balance everything out. I like things smoothed, but I'm slightly concerned about overshoot with S1 cams and a stock turbo. In any case, I'm still much better off with ecu controlled boost than I was with the Tru-boost
edit: LOL I now notice your sig also
Old Jun 16, 2008 | 09:05 PM
  #32
tephra's Avatar
ahh right well V5 is fairly well tested, but yes if you find anymore bugs let me know
the overshoot isn't really too bad, because we are updating the sample so quickly...
Old Jun 17, 2008 | 08:57 AM
  #33
gamebred26's Avatar
how do you reverse these patches on ECU Flash once it's on there? I did one of your patches but don't have the confidence to mess with the no lift shift...vale..etc.
Old Jun 17, 2008 | 09:04 AM
  #34
TouringBubble's Avatar
You don't really need to remove the patch ... just turn the options off. Or, you could just flash a normal ROM back to the ECU. Not difficult at all.
Old Jun 17, 2008 | 09:49 AM
  #35
Tek3Evo's Avatar
What do we log for the 2byte to 1byte conversion?
Old Jun 17, 2008 | 10:14 AM
  #36
gsrboi80's Avatar
Originally Posted by dude
Another 94170015 volunteer here.
me too
Old Jun 17, 2008 | 05:16 PM
  #37
tephra's Avatar
Originally Posted by tephra
notes:
* avg map replaces the original variable - if you want to log the original please log 0xFFFF8417
* ditto for the rear 02, so log 0xFFFF8409 for the real variable
* 0xFFFF840B has the 2byte->1byte variable so log that and then in evoscan multiple the "x" by whatever factor, ie by default use Eval="1.2*x"
quotequotequotequotequote
Old Jun 17, 2008 | 08:03 PM
  #38
Tek3Evo's Avatar
Sorry man, I'm blind I guess.
Old Jun 17, 2008 | 08:23 PM
  #39
tephra's Avatar
log 0xFFFF840B (or just 0x840B if you are editing only the last part of the MUT entry.)
so pick an unused MUTID, I like 0x40, and stick 0x840B in there, then log MUT40 in evoscan and use the formula that I said above).
What loads are you seeing normally?
Old Jun 17, 2008 | 08:42 PM
  #40
tephra's Avatar
OK I have put 94170015 on the first post.
I will wait for these two ROMS to be tested.
Please test all the current features - especially those in the changelog in post #1.
again usual precautions must be followed these are all untested
Old Jun 19, 2008 | 05:15 PM
  #41
tephra's Avatar
Any feedback for 88590015 or 94170015?
Old Jun 24, 2008 | 10:39 AM
  #42
Guz Man's Avatar
any test results on 88590015 please..
i wish if i can do the test.. but my car is at the shop for 8 weeks doing a full build
Old Jun 24, 2008 | 11:29 AM
  #43
JohnBradley's Avatar
Sorry Dave I havent had much time to give feedback on 5.8. But I will upload it tonight and see what I can get done to give good feedback. Because of how I have my xml setup so I can use the same version of ECUflash to tune my car and customers it takes me awhile to switch things around
anyway enough excuses and I will try to get results
aaron
Old Jun 24, 2008 | 11:32 AM
  #44
jdmevo8313's Avatar
Registered User
I would love to help testing if you could figure out how to get more space for the 96940011 RomID haha
Old Jun 24, 2008 | 05:15 PM
  #45
joyce1bro's Avatar
Originally Posted by cossie1
another 1 here that can test 90550001 and I have mine setup to test adc0f
hey cos you still testing this ROM?? hows it looking??
