Evoscan v2.4 fixes
Old Jul 20, 2008 | 06:16 PM
evo4mad's Avatar
Evoscan v2.4 fixes
Anybody want any fixes done for evoscan v2.4? I'll be sending out tonight a new EvoScan v2.5.
1) Subaru SSMI timeouts/connection issues - solved.
2) Vista 64bit edition was returning all zeros in the results - solved.
3) I've added request_ids for evo9 airtemp/coolanttemp.
any other data.xml changes?
Old Jul 20, 2008 | 06:48 PM
mrfred's Avatar
The coolant temp and MAF air temp request IDs work for Evo 8s as well.
Old Jul 20, 2008 | 11:35 PM
evo4mad's Avatar
I've heard that some EDM evos are having problems with the MUT protocol, is that true?
Old Jul 21, 2008 | 06:11 AM
Smogrunner's Avatar
The coolant temp/air temp has been my only issue on my Evo 8. Looks like it has been addressed.
Old Jul 21, 2008 | 07:23 AM
evo828's Avatar
I have evoscanned some EDM evo 8 and 9 - no problems with MUT.
What I am wondering about in 2.4 is why I am getting 100-130 samples/sec vs 150-160 samples/sec when using version 2.1 (of course the same set of items logged).
Old Jul 21, 2008 | 08:15 AM
sub7's Avatar
I want some clarification with injector test. When I initialise one of the injector, it "receives data" for like 5 sec. Where are those data/code "receive" stored and what test is actually being performed by evoscan 2.4?
Old Jul 21, 2008 | 08:24 AM
ecuflasher's Avatar
I'm having issues with many dropped samples from my LC-1 wideband.....is this a common problem? I tested with Mitsulogger and it worked fine.
p/s I didn't log alot of stuff too...
Old Jul 21, 2008 | 08:36 PM
fixem2's Avatar
Can't clear OBD codes. Can read them, but won't clear.
Old Jul 21, 2008 | 09:26 PM
oldevodude's Avatar
It would be nice if ther torque and HP calcualtion work. Is it just me? If I log with old Evoscan .99 and place data in Dataloglab it works. I imagine it's just a formula or something. Anybody getting HP and torque figures accurate?
Old Jul 22, 2008 | 06:55 AM
evo4mad's Avatar
I had an "experienced" programmer help me to add multithreading to EvoScan. Not sure if it was worth the effort, but it definately helped run the gauges and graphs more efficiently at the same time and UI interaction response.
Old Jul 22, 2008 | 06:56 AM
evo4mad's Avatar
I used a formula an evolutionm forum member posted, I may revise it somewhat in the near future.
Old Jul 22, 2008 | 06:57 AM
evo4mad's Avatar
EDM, JDM, or USDM ? what is the 4 letter ecuid that comes up when you datalog?
Old Jul 22, 2008 | 07:52 AM
fixem2's Avatar
USDM, will grab the ECUID tonight. It was E4C something I think.
Old Jul 22, 2008 | 10:49 AM
oldevodude's Avatar
Can't you simply mirror or copy the way Dataloglab does it?
Currently i use evoscan .99 then import into Dataloglab for HP and torque
PS this is meant to be constructive and not destructive by the way
Thanks
Old Jul 22, 2008 | 11:00 AM
fixem2's Avatar
oldevodude, he was asking for the 4 letter ID because I can't clear the codes in the DTC portion of EvoScan.
