Stock Evo 9 IDC's
Old Aug 6, 2008 | 06:50 PM
RazorLab's Avatar
Stock Evo 9 IDC's
I knew this awhile ago but I never posted anything about it. Self tuners here that have logged their stock 9's (when they where stock) probably know this as well but it's good information anyway.
A stock 9 runs very rich up top (10.2-9.8 ) AFR, thus it also runs very high injector duty cycles.
Here is a comparison of IDC 100% stock and after my base flash:
Just a wee bit better. Base flash running 11.0 AFR up top, stock flash was running approx 9.8-10.2
98% IDC compared to 80%.
This was a 100% stock Evo 9, on 91 octane, with the factory flash. My base flash is not a custom tune, but it still made good gains:
Runs less timing up top (stock timing maps knock on 91 octane). Boost is 100% the same between factory and base flash as wgdc is maxed out stock.
The biggest gain with my base flash was 6600 rpm and up, where the factory map takes a nose dive because of a very rich AFR. In this case, it is a 47whp gain going to my base flash over the factory map. Peak torque gains of 22wtq, approx 37wtq up top and a large gain to spool over the factory map.
Again, this is a 100% bone stock Evo 9 with the only mod being my Base Flash.
And three pulls back to back with no cool down to verify the base flash was consistent:
Old Aug 6, 2008 | 06:56 PM
Tuner@Swift's Avatar
Nice, Bryan. I've seen this in every IX that I've tuned. I can also easily max out the stock injector's with an 11.9:1 AFR and 25 psi. I always recommend 750cc injector's to my customer's with IX's even if they will never upgrade from the stock turbo.
Old Aug 6, 2008 | 07:12 PM
tephra's Avatar
Nah stock injectors are ok...
Now fit a gm3port to that IX and bump the boost up a bit
Old Aug 6, 2008 | 07:17 PM
RazorLab's Avatar
I've done a bunch of stock 9's with our boost assembly (oem line and upgraded pill) and a flash and they usually gain another 30whp/25wtq, usually making around 270whp/265wtq on our dyno
The 8's usually need a TBE, boost control and a flash to make that power on our dyno.
I still think the 9's are the best Evo's yet. I might change my mind after I work with the 10's more.
Old Aug 6, 2008 | 08:30 PM
mrfred's Avatar
Its amazing how much the lean spool disable at 7000 rpm richens the AFR.
Old Aug 6, 2008 | 08:35 PM
RazorLab's Avatar
yea those IDC's jump up at 6900-7000 like they are shooting for the moon.
Old Aug 6, 2008 | 10:20 PM
JohnBradley's Avatar
25psi on a stock turbo at 11.9 was maxed? Wow, must be some good air. I think the most I saw on mine on the stocker with stock injectors at that level was 93-94%. That was with pipes, 3" TBE, and an HKS 280 back when MIVEC was young...heheh
Old Aug 6, 2008 | 10:34 PM
tephra's Avatar
25psi not at redline thou :P
do you guys get spark blowout at 24psi+? (obviously I could regap them but meh!!!)
Old Aug 6, 2008 | 10:44 PM
RazorLab's Avatar
I've run 28-29psi on a bunch of 9's with no breakup on stock plugs and ignition.
Old Aug 6, 2008 | 10:45 PM
Thats where the break up usually seems to start happening if its going to and generally gets more aggressive the higher the boost. .020-.021 gap usually cures it right up though.
Nah it was 25-26 peak (about 285-290 load) dropping to 220s by redline (so probably 21?)
I didnt orignally start having problems till about 30 on racegas
Old Aug 6, 2008 | 10:48 PM
RazorLab's Avatar
I just recently started having some breakup right at peak boost after upping my boost from 28 to 30psi. But not all the time. I am beginning to think my stock coils are getting weak or something from all the hell I have put them through, or I have a boost leak
Old Aug 6, 2008 | 10:53 PM
tephra's Avatar
lol you guys are crazy
Old Aug 7, 2008 | 05:00 AM
RAbishi's Avatar
Yeah, no kidding. That is horrible.
Old Aug 7, 2008 | 08:06 AM
dudical26's Avatar
Might be plug wires, from what I have heard they wear out way before coils.
I have been lucky to not have any breakup so far. I have gone as far as 31-32 psi on meth with no problems. I'm keeping my fingers crossed.
Old Aug 7, 2008 | 02:20 PM
To me, anything over 90% IDC is maxed. I don't like the idea of injectors going static on a customer's car. On my car, I don't care as much.
