TephraMOD V5.10
Old Oct 5, 2008 | 03:12 PM
  #376
cossie1's Avatar
Originally Posted by John F
Bet you didn't put your immobilizer code into the Tephra ROM.
He's using a 7 ecu on an evo4.
So no immobiliser code to put in.
But he didn't change the 0000 immobiliser code tephra put in, to FFFF
Old Oct 5, 2008 | 05:10 PM
  #377
evo4mad's Avatar
The OpenPort 2.0 is going to be superseeded by a new LCD touchscreen reflashing device, so I will release both at the same time. So that people can make a decision on which to go with. EvoScan v2.6 Newsletter is ready to go out. I added the priority code for Tephra, and added 1byteload to EvoScan v2.6
(OpenPort 2.0 support will be very soon, I already have openport2.0 working in EvoScan v2.7)
thanks cossie1,
90550001 v5.10
I disabled immobiliser by setting it from 0000 to FFFF
I disabled EGR check by setting perephery2 8A89 to 8D89
I disabled O2 Heater check by setting perephery 56D0 to 16D0
Old Oct 5, 2008 | 06:29 PM
  #378
steadly2004's Avatar
thanks cossie1,
90550001 v5.10
Any chance for Linux support?
I'd really love to get one of those mini PC's.
http://www.newegg.com/Product/Produc...82E16834220270
Old Oct 5, 2008 | 07:46 PM
  #379
EatSleepBoost's Avatar
EVO4MAD any updates for the external wideband.. specifically any changes to the LC-1 datalogging troubles many people are having (myself included) for the new version of EvoScan????
Old Oct 6, 2008 | 01:16 AM
  #380
napolean's Avatar
when i first put the 90550001 rom in my car it kept turning off as well and I found it to be valet mode defaulted to fresh ignition and 114 revs so I just switched valet mode off if that helps evo4mad
Old Oct 6, 2008 | 02:30 AM
  #381
SPAWN's Avatar
Do you have 9747001 for me??
Old Oct 6, 2008 | 07:27 AM
  #382
MR Turco's Avatar
Tephra Mod request: I don't use valet mode ever but can we have other things activated by the same method of turning on valet mode (gas pedal)? I would personally like to turn NLTS on and off using that method, or maybe alt maps. Not sure the scope of this but just wanted to put the request in.
Thanks
Old Oct 6, 2008 | 09:03 AM
  #383
Jack_of_Trades's Avatar
Thanks
Personally, if you set the NLTS settings correctly you really shouldn't ever have it activate unless you're in a situation where you'd WANT to be using NLTS anyways. I'm still working on a really easy fix for the trigger happy clutch switch so people don't kiss their windshields when they rest their shoe on the clutch prematurely. Its definitely a feature which makes you use your clutch pedal perfectly
Old Oct 6, 2008 | 09:55 AM
  #384
MR Turco's Avatar
When i am taking logs or just messing around on the street i don't always want to shift like i am drag racing. I still really need to play with it and see.
Old Oct 6, 2008 | 11:34 AM
  #385
If you let off the gas even slightly (go below your tps setting), you've shut off NLTS anyways so if you shift like normal you'll never even be using the NLTS feature.
Old Oct 6, 2008 | 03:27 PM
  #386
tephra's Avatar
both good points. I will see if I can easily implement a flag that lets u swap the activation method for valet to NLTS...
Old Oct 6, 2008 | 04:35 PM
  #387
MR Turco's Avatar
You the man tephra!
Old Oct 7, 2008 | 05:21 PM
  #388
ciobing's Avatar
Originally Posted by tephra
Jamie - 1byte load is just 2byte load squished into 1byte.
Just saves on logging speed and the out of order HB/LB problem (leads to spikes in load graph)...
2byte is more accurate?
In the map tracer's cell,I have to consider 2byte or 1byte(where it can correspond another cell with load slightly different)?
Old Oct 7, 2008 | 11:38 PM
  #389
EvoIXMR's Avatar
Tyring to work with 94170015 so I can replace my 96420007 map....
1) I switched the CHANGEME to big as I have ecuflash 1.35
2) I copied over the XML stuff and then tried to open the 015 file in evoscan...
Issues I am having:
1) Under Misc section, for Wastegate Compensation, I get the following error:
"The current map description is invalid or incomplete. Please edit the map description to fix the problem and the map will be viewable again"
2) Also, the map title is in light gret and so are some other maps like Init Code and Boost Enhancement Table as well as several others...
3) Also, I See that Tephra suggests to remove Boost Desired Engine Load #2 and #3, only #1 matters anymore, but I have #1, #2, #3 and #4...should I remove #4 as well...
<table name="Boost Desired Engine Load # 1" address="44f8">
<table name="RPM" address="6982" elements="16"/>
</table>
<table name="Boost Desired Engine Load # 2" address="450e">
</table>
<table name="Boost Desired Engine Load # 3" address="4524">
</table>
<table name="Boost Desired Engine Load # 4" address="453a">
</table>
4) Remove/Rename your current "Base Wastegate Duty" #2 and #3, only #1 matters anymore - My 015 map does not have #1, #2 or #3
I am n00b to this, so I could be doing something wrong!
Thanks!
Old Oct 8, 2008 | 12:51 PM
  #390
EvoIXMR's Avatar
anybody?
