TephraMOD V5.10
Hello Tephra-
Any idea if you will work on ROM 96420008? I have searched around to see if it was available, I don't believe it is. I'd really like to try your mod out
Thanks!
-Bink
Thanks!
-Bink
yeah but i thought the immobilizer doesnt work when you load it on? I would love to move my buddy to that version but he wants the immobilizer.
what - is that true? I didn't know this. I copied my immobilizer code over and sent it on to Mellon. Crap
EDIT - researched disabling immobilizer and found the 2 threads that seem to help...
https://www.evolutionm.net/forums/sh...le+immobilizer
Is there a place where I can download the new ROM and try it out?
-Bink
Hi Bink
The 1st page has tephra's additions. The stock rom can be found in any version of ecuflash in the rommetadata folder. Do know that the 015 map in version 1.38 has some weird table called wastegate compensation showing and needs to be deleted from the XML, its discussed in the last 2 pages....
Jack of Trades has tested this v5.10 015 ROM and said its great.
Hope this helps!
KC
Hi Bink
Hope this helps!
KC
Hope this helps!
KC
This is also untrue. The stock ROM can not be found in the rommetadata folder. These are XML files containing definitions for EcuFlash. Stock Roms can be found in the wiki that was started which can be found at http://evoecu.logic.net/wiki/Main_Page
EDIT
So, you have an 04 Evo, it seems like...I do too, ignore my username - sold my MR a while back. What ROM do you run in the car, sir?
Hey guys-
After reading through everyone's responses...
I'm still a little confused.
Would trying to run the 94170015 ROM in my 2004 USDM EVO8, be a good idea (the one that is in there now is the 96420008 ROM)?
I assume if the car doesn't start - you can always re-flash the ECU again to go back to the original one. Is it just a matter of trial and error?
-Bink
-Bink
