TephraMOD V5.10
Old Oct 11, 2008 | 04:21 PM
  #436
AlwaysinBoost's Avatar
Originally Posted by tephra
Yeah I have to do two ROM's 88840017 and 96420011
I will hopefully have the done next week
sweet, cant wait
Old Oct 11, 2008 | 08:31 PM
  #437
fixem2's Avatar
Mellon, I confirmed the 96530006 ROM as the Stationary Rev limit within the ROM via Ecuflash. I have not verified it works properly, will do tomorrow.
Old Oct 11, 2008 | 09:52 PM
  #438
cossie1's Avatar
88570008 UNTESTED
This rom is bugged I think.
Alternate Hi Octane Ignition Map #123
Alternate Low Octane Ignition Map #123
Alternate Base Wastegate Duty #1
Alternate Base Wastegate Duty #2
Alternate Boost Desired Engine Load
all don't seem right
Old Oct 11, 2008 | 11:05 PM
  #439
grayw's Avatar
Seems to work fine, running on 2 JDM IX's, but not using the switchable maps.
Originally Posted by cossie1
88570008 UNTESTED
Old Oct 11, 2008 | 11:35 PM
  #440
cossie1's Avatar
It's only the alternate stuff that seems bugged.
Old Oct 11, 2008 | 11:44 PM
  #441
tephra's Avatar
what do you mean doesn't work?
Old Oct 11, 2008 | 11:51 PM
  #442
cossie1's Avatar
The alt map ignition tables are wrong (should be 19 rpm lines instead of 20).
And if you alter:
It changes the alt low octane ignition map.
Old Oct 12, 2008 | 12:00 AM
  #443
cossie1's Avatar
This is what I get.
Attached Thumbnails TephraMOD V5.10-untitled1.png   TephraMOD V5.10-untitled2.png
Old Oct 12, 2008 | 01:13 AM
  #444
tephra's Avatar
crap - must be a definition problem...
I will check/fix it tommorow. I am sure the ROM is ok..
Old Oct 12, 2008 | 09:37 AM
  #445
cossie1's Avatar
Ok mate, no problem.
Old Oct 13, 2008 | 12:45 PM
  #446
fixem2's Avatar
Mellon, confirmed the 2-step works on 96530006 ROM which replaces the 05 8 ROM. Convert away!
SIde note, sent an email through your contact page for tuning.
Old Oct 13, 2008 | 01:03 PM
  #447
Mellon Racing's Avatar
cool thanks for the confirmation!
I replied to all of my tuning e-mails so you should have gotten a response by now
Old Oct 13, 2008 | 03:48 PM
  #448
tephra's Avatar
96260009 UPDATE
Hi guys there was a minor bug in 96260009 that stopped the 'restore ics state' from working.
I have uploaded a new version (with 'fix' in the filename). However if you dont want to start from scratch just add this to you xml and then change 0x8520 to 0x851E
Code:
<table name="ICS StateRestore BUGFIX" category="Mods" address="f68a" type="1D" scaling="Hex16"/>
Old Oct 13, 2008 | 04:13 PM
  #449
tephra's Avatar
UPDATE 88570008
As Cossie1 has reported there was a problem with the altmaps overwriting each other.
Unfortunately its not just a definition fix - please redownload the full zip file and use a new definition AND ROM.
Old Oct 13, 2008 | 04:33 PM
  #450
cossie1's Avatar
UPDATE 88570008
Cheers Dave.
Glad it wasn't just my definition file
