TephraMOD V5.10
Old Oct 22, 2008 | 11:34 AM
  #511
EVIL_EV0's Avatar
So downloading a fresh version of 2.4 then adding the one line of XML provided in post 1 will net me full logging for Airflow, 2byte, 1byte, and alt map activity?
If so that would be sweet.
Old Oct 24, 2008 | 01:25 PM
  #512
major's Avatar
Hi everyone, beside me problem.install ecuflash 1.40 (copy to OpenECU\EcuFlash\rommetadata\mitsubishi\evo => evo7base,90550001.xml by cossie 1). start the program, choose 90550001-v5.10fix-mods, he writes can not load. please help .
Old Oct 24, 2008 | 09:47 PM
  #513
Jeff_Jeske's Avatar
^ Hard to understand you. Were you able to build the map on your PC but unable to load the map into the car?
I had the same problem with version 1.38. I don't think my older cable works with the newer code.
Old Oct 25, 2008 | 03:54 PM
  #514
04gsna's Avatar
hey sorry for a NOOB post but everytime I try installing I fail, Ive reinstalled Ecuflash over 10 times and Im wondering if someone can email me the full folder from 94170015. id be greatful.
email is 04gsna@gmail.com
i have 1.40
Old Oct 26, 2008 | 05:00 AM
  #515
tephra's Avatar
whats the actual problem?
Old Oct 26, 2008 | 07:44 AM
  #516
04gsna's Avatar
it says error on line 258 everytime I load the ROM
Old Oct 26, 2008 | 08:39 AM
  #517
Jack_of_Trades's Avatar
Then if you open up your XML file with notepad and scroll down to line # 258, there will be an error on that line. If you don't know what line is #258, in the bottom righthand corner of your notpad screen it should tell you what line # and row# the cursor is currently on. If you copy and paste the line on here we can see what is wrong for you.
Old Oct 26, 2008 | 03:17 PM
  #518
tephra's Avatar
what is line 258?
Old Nov 2, 2008 | 06:06 PM
  #519
03whitegsr's Avatar
I have some feedback on the 94170015 ROM with this patch, and I'm wondering if anybody else has experienced the same things. Prior to switching to V5.10, I had not noticed any of these issues. However, the knock light does make things more apparent.
On start up, I start the car and then the first time I push the throttle, I'll get a very noticeable hesitation. Only on the first blip of the throttle, kind of odd. Also, it seems like until I push the throttle, every time I push the clutch in, the idle speed climbs about 300 RPM. Let the clutch out and it falls right back to where it was. Both of these issues seem to disappear after pushing the throttle once or twice. It's no big deal, just wondering if anybody else had noticed this behavior?
Second problem is however an issue. I get part throttle tip-in knock constantly. The datalogs I have gotten of it have shown pretty consistent behavior. It's fairly difficult to get it to do it on demand, but when it does do it, it seems to be the same type of ECU response. The timing will be running roughly what the main timing map is telling it to run. I'll increase the throttle a bit (say from 25% throttle to 50%) and the timing will go to over 40 degrees. From here, it does one of two things. It knocks 1-2 counts, then drops right back to where the map is telling it to be. Or on pulls where this huge jump in timing doesn't result in immediate knock, the ECU will try to run a good 5-10 degrees more advance on a pull then what the map is telling it to run, which then turns into massive knock sums and huge ignition retard through the rest of the pull.
To try and cure some of the ignition retard issues, I have zero'd out the "boost enhancement (anti-lag)" map for ignition and fuel. I have also disabled FAA bit 10. Further, I have reduced peak timing in the main ignition table from 38 degrees to 35 degrees. The combination of these seems to have helped, but not solved my problems.
Old Nov 3, 2008 | 11:25 AM
  #520
Nurburgring's Avatar
I have no issues at all with 94170015 on my ´04 (originally with 94170008), but CEL on knock refuses to work even with Knocksum and Load thresholds taken down to 2 and 40 respectively, flash time 5000ms, and i AM seeing 2-3 counts of knock ocasionally on the datalogs.
BTW thanks for your great work tephra, donated.
Old Nov 3, 2008 | 01:13 PM
  #521
steadly2004's Avatar
Maybe the bulb is burn't out? It works on my ECU which had 94170008 origionally, but flashed in 94170015. Does the light come on when you first turn the key on? i think it should.
Old Nov 3, 2008 | 03:13 PM
  #522
The 94170015 patch is fine, this is something isolated to his install of the patch or something like they said...burnt out bulb. The 94170015 rom is one of the most used patches and it works for everyone else.
Old Nov 3, 2008 | 03:31 PM
  #523
mplspilot's Avatar
I get the tip-in low load knock with this 0015. So i am not using it.
And i have a similar throttle issue, where if i push the clutch in and blip the throttle, the afr's become very lean, like the injectors shut off, all consecutive throttle blips would be fine, unless i release the clutch, push it again, and blip the throttle again — same thing happens. Once the car is warm it goes away. I have that with 0008 as well as 0015 and they both have so many patches, that i have no idea which one is the culprit. But again it only happens when the car is cold and top clutch switch is activated...
So i dunno.. it's not a huge deal, the car just stumbles on gear shifts when cold unless i blip the throttle twice with pressed clutch...
Old Nov 3, 2008 | 03:36 PM
  #524
I have been getting a crapload of tip-in knock on the 94170015 v5.10 rom as well (leanspool disabled). Starting to really annoy me.
Old Nov 3, 2008 | 05:16 PM
  #525
Hmm. I have the same thing, does it continue if you stay on it when it knocks at tip-in (low-rpm)? Because mine does, but if I start the pull later in the rpm's it doens't knock as often
