IX won't connect to PC?? experienced tuner can't figure this one out...
if you can connect to mitsulogger then use that logger. It can log all that you NEED to log.
I don't see why your tuner couldn't use that logger instead, at least until you figure out whats going on with your evoscan/computer
It sounds like it may be a cable problem. I had a cable go bad and it would log but I could not read from or write to the ECU. If there is someone else local to you with a cable you could borrow to rule it out that would be best, otherwise you could just order another one and hope for the best.
-Paul
-Paul
no! it doesn't sound like a bad cable problem. At least nothing obvious. When you were initializing EcuFlash, it was only try to read the port, not writing to it hence similar to the way EvoScan and Mitsulogger did.
To the OP, do you have someone nearby with EvoScan that they can test that specific logger on the car with your cable?
OH GREAT! Well, I don't know what to do now. ITS NOT THE CABLE. My tuner sent me a new one and that one gave the same error message. PLEASE DOES ANYONE HAVE ANY IDEAS??? Could my car's electrial stuff be messed up somehow? Im really worried now because if its not the cable and I dont think its the software/computer then it must be the car.... HOW??
sorry, im just venting a little. I really need a tune.
If anyone has any ideas or anyone they could recommend talking to I would appreciate it
XBS--- Please let me know whats happening to you and whether or not you got it fixed. thanks.
hearnoevo
Oct 14, 2016 09:15 PM
