New Maps for Evo 7 and 9
Old Aug 24, 2008 | 05:31 AM
  #31
fixem2's Avatar
2005 Evo 8 ROM = 96540011. This can be converted to the EDM 05 ROM = 96530006.
Old Aug 24, 2008 | 08:20 AM
  #32
Jack_of_Trades's Avatar
I think the most common Evo8 rom is the 94170008 but everyone with the 0008 and 0014 roms upgrade to the 94170015 so I'd work on that one first. I love seeing new maps popping up. There are so many left that are undefined...yet useful for all of us.
Old Aug 24, 2008 | 08:46 AM
  #33
Jersey Dino's Avatar
hey mattjin, I am new to exploring the ECU BUT, I have a ix and woudl be willing to do some incar testing if needed. regarding the throttle hanging I changed some values in the ISCV table that EVO KID posted a while back. It seems to be a good bandaid/fix, but my idle sufers a little bit, so maybe this is the answer! let me know if you need help testing with an EVOIX
Old Aug 24, 2008 | 11:39 AM
  #34
fostytou's Avatar
EvoM Community Team
Originally Posted by Mattjin
Yes add the line but your Enrich scaling is screwed up in the forumula. Erase it and use the scaling line I provided in the first post of this thread, then the map should read correctly.
Sorry, read through things too quickly... got it looking much better now. Why do the temp(C) values still look so silly?
Thermo Fan map for 88590015:
Don't forget to add the Percentage Scale posted elsewhere on this thread.
just had to change yours (or the scaling itself) to match... I changed your scaling call to "Percent (128)". Anyone know what these conditions are? I would guess some of the secondary conditions would be for turning on the AC fan, but I'm not sure.
Old Aug 24, 2008 | 11:57 AM
  #35
Jorge T's Avatar
I found some for 94170008 by using the guestimation method, someone with dissasembly skill please check if they are ok.
I'm still looking for the rest.
<table name="Ignition Trim vs Air Temp" category="Timing" address="41b2" type="2D" level="2" scaling="Enrich">
<table name="Air Temp" address="6c24" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="Ignition Trim vs Engine Temp" category="Timing" address="41a4" type="2D" level="2" scaling="Enrich">
<table name="Engine Temp" address="6c24" type="Y Axis" elements="8" scaling="Temp"/>
</table>
<table name="Ignition Trim Untested" category="Timing" address="41c0" type="2D" level="2" scaling="Enrich">
<table name="Engine Temp" address="63b4" type="Y Axis" elements="5" scaling="Temp"/>
</table>
<table name="Ignition Trim vs Air Temp Active Above Load" category="Timing" address="41cc" type="2D" level="2" scaling="Load8">
<table name="Engine Speed" address="61da" type="Y Axis" elements="10" scaling="RPM"/>
</table>
<table name="Warmup Ignition Retard Temp Control" category="Timing" address="41dc" type="2D" level="2" scaling="uint8">
<table name="Engine Temp" address="65c6" type="Y Axis" elements="8" scaling="Temp"/>
</table>
ps. I won't be upgrading to 0015 any time soon
Old Aug 24, 2008 | 03:59 PM
  #36
Mattjin's Avatar
Seem OK for 94170008. Maps look correct.
Here is the Thermo Fan map for 94170008
<table name="Thermo Fan Duty" category="Misc" address="459a" type="3D" level="2" swapxy="true" scaling="Percent (128)">
<table name="Conditions" type="Static X Axis" elements="9">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Engine Temp" address="65a4" type="Y Axis" elements="12" scaling="Temp"/>
</table>
Old Aug 24, 2008 | 04:58 PM
  #37
Jorge T's Avatar
thanks!, beat me to it...
here are the rest for 0008
<table name="Decel Fuel Cut Delay - Neutral A/C Off" category="Fuel" address="42bc" type="2D" level="2" scaling="uint8">
<table name="Load" address="650a" type="Y Axis" elements="7" scaling="Load"/>
</table>
<table name="Decel Fuel Cut Delay - In Gear A/C Off" category="Fuel" address="42ca" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Delay - Neutral A/C On" category="Fuel" address="42d8" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Delay - In Gear A/C On" category="Fuel" address="42e6" type="2D" level="2" scaling="uint8">
</table>
<table name="Decel Fuel Cut Ignition Retard" category="Fuel" address="4300" type="2D" level="2" scaling="Timing">
</table>
Old Aug 24, 2008 | 05:26 PM
  #38
dude's Avatar
I second this; I've upgraded from 008 to 94170015 and know of quite a few others who have as well. I figure this ROM ID would cover the single largest number of USDM Evos...
Old Aug 24, 2008 | 05:40 PM
  #39
Jumperalex's Avatar
especially since Tephra is only supporting 0015
Old Aug 24, 2008 | 05:44 PM
  #40
l2r99gst's Avatar
I think this is the fan map for 96940011:
Code:
<scaling name="Percent (128)" units="%" toexpr="x/1.28" frexpr="x*1.28" format="%.0f" min="0" max="100" inc="1" storagetype="uint8" endian="big"/>
	<table name="Thermo Fan Duty" category="Misc" address="3C16" type="3D" level="2" swapxy="true" scaling="Percent (128)">
	<data>On1</data>
	<data>On2</data>
	<data>On3</data>
	<data>Off1</data>
	<data>Off2</data>
	<data>Off3</data>
	<data>A/C1</data>
	<data>A/C2</data>
	<data>A/C3</data>
	</table>
	<table name="Engine Temp" address="5dec" type="Y Axis" elements="12" scaling="Temp"/>
	</table>
Eric
Old Aug 25, 2008 | 02:44 AM
  #41
Mattjin's Avatar
Small typo there Eric. Scale address for Engine temp is 5dec, not 5ded. Close though. :-)
Old Aug 25, 2008 | 02:48 AM
  #42
Mattjin's Avatar
I would check things for 94170015 but I dont have the rom or def. Not much demand for it here in sunny Oz. I am sure some of you smart fellows will find it, but if not let me know.
Old Aug 25, 2008 | 03:19 AM
  #43
SeanV's Avatar
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
</table>
This is great.....
I have the 9653006 Evo8 ROM, same as the AUS market. Would the above work on my ROM?
Thx.
Old Aug 25, 2008 | 04:27 AM
  #44
Mattjin's Avatar
Actually 96530006 was the only Evo8 I did before posting. Here it is:
<table name="Thermo Fan Duty" category="Misc" address="45ac" type="3D" level="2" swapxy="true" scaling="Percent">
<data>On1</data>
<data>On2</data>
<data>On3</data>
<data>Off1</data>
<data>Off2</data>
<data>Off3</data>
<data>A/C1</data>
<data>A/C2</data>
<data>A/C3</data>
</table>
<table name="Engine Temp" address="6a14" type="Y Axis" elements="12" scaling="Temp"/>
</table>
Old Aug 25, 2008 | 05:52 AM
  #45
l2r99gst's Avatar
Yep. I fixed it in my post. Thanks for catching it.
