EcuFlash Version 1.37 released
Old Sep 7, 2008 | 12:50 PM
EFIxMR's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=363612
Here's a link to some of the USDM EVOX rom definitions.
Old Sep 7, 2008 | 12:58 PM
TTP Engineering's Avatar
Originally Posted by High_PSI
Man I still have such an OLD version, I am SO afraid to upgrade with all these issues
Welcome to our life. We also use Evoscan 0.99.
If it ain't broke, don't fix it.
Old Sep 7, 2008 | 01:01 PM
EvoDan2004's Avatar
i use evoscan 2.1 with zero issues at all....
and i am still on ecuflash 1.29 as it seems to still be the best so far
Old Sep 7, 2008 | 01:41 PM
EFIxMR's Avatar
yea, i run 1.29a also, using it everyday, bugs would drive me nuts.
Old Sep 7, 2008 | 02:40 PM
Mattjin's Avatar
I always thought the problem was more to do with the drivers it installs with each new version. My cable was sourced from Limitless when I bought Evoscan and is a 1.3U unit. V1.35 and V1.37 both open and run without fault up until I do a Read i.e. try to access the cable. I might do another install this morning and choose not to install the drivers and see the effect.
Old Sep 7, 2008 | 03:48 PM
Jumperalex's Avatar
odd ... I never have problems with 1.35 / 2.5 and now no problems with 1.37 / 2.5 [shrug]. Now I will go outside and get pissed that nothing works haha
Old Sep 7, 2008 | 04:55 PM
High_PSI's Avatar
Amen Sir.
Old Sep 7, 2008 | 05:55 PM
evo8dad's Avatar
Is there a way to access older versions? I'd like to swich back hto an earliervereion to see if the graphs work.
Old Sep 8, 2008 | 10:48 AM
dudical26's Avatar
Does this support logging to the SD card with the new cable? There must be some way to configure the SD card logging with the new cable.
Old Sep 9, 2008 | 03:17 PM
G20's Avatar
G20
Colby just released 1.38 which fixed the graph issue and apparently work with some CAN ecu.
Old Sep 10, 2008 | 05:19 AM
Mattjin's Avatar
Same old issues for me for v1.38. Crashes on rom read but works fine for viewing.
evoscan
52
Jun 20, 2017 01:46 AM
city
Jun 2, 2017 08:34 PM
franmf
May 16, 2014 03:20 AM
lonestarevo83
Jul 15, 2011 07:20 PM
CLaNZeR
Jan 31, 2009 02:26 PM
