EcuFlash Version 1.37 released
Old Sep 5, 2008 | 08:04 PM
fryedchikin's Avatar
For those who have not already noticed....
# 2008-09-05: Version 1.37 released
* the main features of this release is support for Subaru CAN vehicles and the J2534 OpenPort 2.0 cable
* this release has no Subaru CAN definitions in it yet - those will be supplied in a few weeks once we collect all of the new ROMS.
* some mitsubishi definitions have been updated (thanks mychailo!)
* J2534 OpenPort 2.0 applications supported with new op20pt32.dll
* op20pt32.dll automatically updates OpenPort 2.0 firmware when needed
* test mode connection no longer needed with newer Subaru ISO and CAN vehicles when using OpenPort 2.0
* fix bug with unknown ROMs not carrying memory model through wizard
* fix bug with loading inherited XML when the rommetadata path is a relative one
* make shbootmode less picky about receiving ACK responses
Old Sep 5, 2008 | 09:17 PM
steadly2004's Avatar
sounds like its not as much an issue for the EVO....
Which definitions have been updated BTW?
Old Sep 6, 2008 | 12:15 AM
Mattjin's Avatar
Got it.
Still crashes on ROM Read for me the same as V1.35 did. I am running Vista Business 32-bit with EVO 7. V1.34 is the last working version for me that runs without fault. Anyone else having the same problem?
Old Sep 6, 2008 | 12:19 AM
al\lupo's Avatar
On XP I can't see graphs with 1.37...
Old Sep 6, 2008 | 10:22 AM
RazorLab's Avatar
Takes my computer down everytime I try to install it.
Old Sep 6, 2008 | 10:27 AM
Jumperalex's Avatar
I can see graphs but they start small so you have to stretch them to size again. which is nice because now you can resize the table windows.
fyi I'm on XPSP3, but I haven't read/written anything yet, just messed about with my tables and xml definitions (nothing has changed in evo7 / 94170015 btw)
oh yeah but 1.35 gave me no problems either.
Old Sep 6, 2008 | 10:28 AM
I have the same problem with the graphs . Guess I will go back to 1.35.
Old Sep 6, 2008 | 10:44 AM
Jumperalex's Avatar
are you sure they aren't just squished to the left? try resizing the right side of the window after turning on graph view.
Old Sep 6, 2008 | 01:28 PM
randomevo's Avatar
you can resize the table window, but the table doesn't seem to get any bigger, only the graph ;-(
Old Sep 6, 2008 | 06:16 PM
evo8dad's Avatar
I'm having the same graph problem but, with v1.35 in XP via Parallels on my MAC. Actually the graph box opens but, now graph shows up?
Old Sep 6, 2008 | 06:28 PM
High_PSI's Avatar
Man I still have such an OLD version, I am SO afraid to upgrade with all these issues
Old Sep 7, 2008 | 09:53 AM
mrfred's Avatar
Good news is that v1.37 can read an Evo X ROM that's already been retrieved from an ECU, so we can start building a definition file for for the Evo X ROMs.
Old Sep 7, 2008 | 10:06 AM
RazorLab's Avatar
I was reading that euro X rom with 1.30
Old Sep 7, 2008 | 10:08 AM
mrfred's Avatar
Hmm. I couldn't get it to read. Oh well. Now I'm surprised that no one has posted any definition files. Could you email me what you have for the Euro or USDM X ROM?
Old Sep 7, 2008 | 10:41 AM
RazorLab's Avatar
Have fun, the sooner we can tune/flash Evo 10's the happier I will be.
<table name="High Octane Ignition Map 1" address="5590b">
<table name="Engine Load" address="60a0c" elements="22" scaling="Load"/>
<table name="RPM" address="609d8" elements="23"/>
</table>
<table name="Low Octane Ignition Map 1" address="55b0d">
</table>
<table name="High Octane Fuel Map" address="5517f">
<table name="Engine Load" address="60992" elements="21" scaling="Load"/>
<table name="RPM" address="6096c" elements="16"/>
</table>
<table name="Low Octane Fuel Map" address="552d7">
<table name="Engine Load" address="60876" elements="21" scaling="Load"/>
<table name="RPM" address="60946" elements="16"/>
</table>
<table name="High Octane Fuel Map 1" address="55027">
</table>
<table name="Low Octane Fuel Map 1" address="55027">
</table>
<table name="VVT Map 1 (Main)" address="5d7f7" scaling="ValveTiming">
<table name="RPM" address="6104a" elements="24"/>
</table>
<table name="VVT Map 2 (Main)" address="5d9f7" scaling="ValveTiming">
</table>
<table name="VVT Map 3 (Main)" address="5dbf7" scaling="ValveTiming">
<table name="Engine Load" address="60a0c" elements="21" scaling="Load"/>
</table>
<table name="VVT Map 4 (Main)" address="5ddf7" scaling="ValveTiming">
</table>
<table name="Boost Limit" category="Turbo" address="555b4" type="2D" level="1" scaling="LoadBoost">
<table name="RPM" address="60ff0" type="Y Axis" elements="9" scaling="RPM"/>
</table>
<table name="Injector Battery Voltage Latency Compensation" category="Fuel" address="556cc" type="2D" level="1" scaling="InjectorLatency">
<table name="Battery Voltage" address="608fc" type="Y Axis" elements="7" scaling="BatteryVoltage"/>
</table>
<table name="Boost Target1" category="Turbo" address="5e623" type="3D" level="1" swapxy="true" scaling="BoostBar">
<table name="TPS" address="61ee8" type="X Axis" elements="14" scaling="Volts16"/>
<table name="RPM" address="63710" type="Y Axis" elements="17" scaling="RPM"/>
</table>
<table name="Boost Target2" category="Turbo" address="5e719" type="3D" level="1" swapxy="true" scaling="WGDuty">
</table>
<table name="Boost Target3" category="Turbo" address="5e80f" type="3D" level="1" swapxy="true" scaling="WGDuty">
</table>
<table name="Max WGDC A" category="Turbo" address="5e719" type="3D" level="1" swapxy="true" scaling="WGDuty">
</table>
<table name="Knock filter map 1" category="Misc" address="56647" type="3D" level="1" swapxy="true" scaling="Hex16">
<table name="Load" address="60876" type="X Axis" elements="21" scaling="Load"/>
<table name="RPM" address="60946" type="Y Axis" elements="16" scaling="RPM"/>
</table>
<table name="Knock filter map 1" category="Misc" address="566ff" type="3D" level="1" swapxy="true" scaling="Hex16">
</table>
