how-to: control closed loop AFR with your wideband O2 system
Old May 14, 2010 | 02:47 PM
  #241
3gEclipseTurbo's Avatar
Just download that rom did the patch and swapped over the front/rear o2 sim stuff. Will be trying this after i mow my lawn. THANK YOU!!!!!!
Old May 15, 2010 | 07:24 AM
  #242
Creamo3's Avatar
I assume your using V7? How did it turn out?
Old May 15, 2010 | 03:24 PM
  #243
Yes Im on v7. Ok so i put it on the car, it works good for the first 30sec or so then the fuel trim spikes to -25 and the car will sputter and die from lack of fuel.
Old May 15, 2010 | 04:14 PM
  #244
Im using aem ugeo if that might change a formula in the patch or something..
Old May 16, 2010 | 10:34 AM
  #245
still no luck. at first it will start strong but then the stft will go from -5 to -25 an the afr will go over 18.4 and the car dies.
Old May 16, 2010 | 02:45 PM
  #246
mrfred's Avatar
The EUGO definitely requires a different formula. Have you searched this thread for it?
Old May 17, 2010 | 09:00 AM
  #247
fostytou's Avatar
EvoM Community Team
I have posted the UEGO formula either here or in the rear02 logging thread...
Old May 18, 2010 | 07:18 PM
  #248
Originally Posted by fostytou
FYI for anyone with an AEM wideband here is the equation and a chart:
http://thefrost.net/randomfiles/tuni...F+R_O2_Sim.xls
Base equation is 0.039137255*V+10
Code:
mL            1/mL             bL/mL
0.039137255    25.5511022    255.511022
Ok so i see where to put the 1/mL and bL/mL but where do i put the mL and base equation?
Old May 19, 2010 | 01:10 PM
  #249
anyone?
Old May 19, 2010 | 01:15 PM
  #250
mrfred's Avatar
anyone?
Only 1/mL and bL/mL are needed.
Old May 19, 2010 | 01:52 PM
  #251
Ok thanks. Im going to try this right now!
Oh and in the rom i download to copy the stuff from to my rom, it had the "cold engine close loop afr" at 235.2, isnt that the afr that the ecu is trying to achive for warmup? So shouldnt that be 13.x or 14.x?
Old May 19, 2010 | 03:07 PM
  #252
mrfred's Avatar
Yes, 14.7 or maybe a little richer if you want.
Old May 19, 2010 | 06:16 PM
  #253
well i put it thoughs numbers but it still isnt working. The logged afr map is 14.8-15.0 but the actual afr going by the wide band is above 18.4afr
Old May 19, 2010 | 08:44 PM
  #254
nothere's Avatar
what?
Old May 19, 2010 | 08:50 PM
  #255
Exactly what I said. if you go by "AFR map" logged by evoscan it says the afr is 14.8-15.0, but the "external wideband" logged by evoscan is above 18.4 as thats as high as the uego reads.
