how-to: control closed loop AFR with your wideband O2 system
Old May 22, 2014 | 06:47 PM
  #406
domyz's Avatar
Originally Posted by wreckleford
Nope, its available for 9653. been using it for over a year.
Where is it?
Old May 23, 2014 | 07:51 AM
  #407
wreckleford's Avatar
Post 240.
Old May 23, 2014 | 09:59 AM
  #408
domyz's Avatar
Post 240.
Thanks, it was well hidden (I searched )
Old May 23, 2014 | 11:36 PM
  #409
jeffbeagley's Avatar
Old Jun 11, 2014 | 07:07 AM
  #410
rich3389's Avatar
I've noticed when inputting "255" to turn off the closed loop control "Closed loop wideband on/off" the ecu is not in fact turning the closed loop afr control off. Am I correct in assuming the value of "1" is on and "255" off?
Old Jun 11, 2014 | 05:18 PM
  #411
I had assumed 1 would be on and 0 would be off, but that doesn't seem to work either. If I want to turn it off I use the closed loop load table.
Old Jun 24, 2014 | 03:38 PM
  #412
rich3389's Avatar
So I am now running the wideband in the front o2 location, and the stock o2 sensor is unplugged. I am getting the CEL for front o2 sensor heater circuit. I tried disabling FAA bit 14 which is the front o2 sensor heater circuit. But I am still getting the CEL for it.
Is there anyway to make changes to the rom to properly delete the stock front o2 sensor or am I going to have to attach resistors to the stock front o2 wiring?
BTW, the sensor acts MUCH faster in the front o2 location and even is more drivable, no more weird bucking at low speeds. I am not concerned about the longevity of the sensor in this location as I ran a wideband in the o2 housing in my DSM for quite some time with no issues.
EDIT: the code im getting is P0031
Old Sep 8, 2014 | 09:55 AM
  #413
domyz's Avatar
Evo8 9653 v7:
Is it possible that changing MUT12 from 8409 to the new value will make afr safety stop working?
Looks like it does not read wideband from first testing this morning.
Old Sep 8, 2014 | 06:12 PM
  #414
domyz's Avatar
Looked in the code and it seemed that the old adress was still unused so no reason to change it.
So I edited the patch like this:
Changed ADC0A/Pin75 variable to 8408
Changed 36A36 from 890A to 8408 for the main sub WB RAM adress
And logged the Wideband at MUT12: 8409.
AFR safety now works. Wideband is logging.
Old Oct 13, 2014 | 05:00 PM
  #415
211Ratsbud's Avatar
can i switch the ram variables and use the front o2 input as the analog input for my wideband o2? would make switching from the stand a lone ecu extra easy.
Old Oct 13, 2014 | 05:01 PM
  #416
I do not believe so because it's only a 1v input.. Please correct me if I'm wrong.
Old Oct 13, 2014 | 05:09 PM
  #417
211Ratsbud's Avatar
but he says you can log what ever you want from the front o2
Old Oct 13, 2014 | 05:36 PM
  #418
With restrictions, and again I could be wrong.. but I believe since the stock narrowband ( front ADC ) is a 1v sensor, then the input can only be 0-1v while a wideband is 0-5v.
Old Oct 13, 2014 | 06:05 PM
  #419
domyz's Avatar
rats it will work all the ecu inputs are 0-5v. you just have to change some variables in the ROM
Old Oct 13, 2014 | 06:10 PM
  #420
211Ratsbud's Avatar
Would you just swap the ram variables in the front and rear o2? Basically back to stock..
