disabling lean spool
Old Nov 12, 2008 | 02:39 PM
  #31
tephra's Avatar
i dont change the leanspool settings on my tephramods.
did u copy ure fuel maps into V5.10?
Old Nov 12, 2008 | 05:41 PM
  #32
Evoryder's Avatar
post#28 i asked...
FBA bit 0 is the same for my Rom ID# 94170015? If so I'll test in the morning or afternoon.
Just need confirmation. Someone else answered referring to the similar rom for 03' evo's.
Thanks
Old Nov 12, 2008 | 09:43 PM
  #33
Evoryder's Avatar
I disabled my FBA bit to 0 and all gears are consistent and just like lean spool dropped by 1 afr point 11's to 10's.
Old Nov 12, 2008 | 09:47 PM
  #34
tephra's Avatar
so you had lean spool "enabled" before (ie 2500/7000rpm)
ie you expected the car to richen up by doing the FBA?
Old Nov 12, 2008 | 10:12 PM
  #35
Evoryder's Avatar
I didn't have an option for lean spool in this rom i'm using. It as in my original rom. The antilag start/stop = 2500/4531
And yes I did expect it richen up
Old Nov 12, 2008 | 10:14 PM
  #36
tephra's Avatar
cool. happy?
Old Nov 12, 2008 | 10:21 PM
  #37
Evoryder's Avatar
cool. happy?
Yes Dave. I am pleased as punch ...
((((((((((((((Thanks)))))))))))))))
Old Nov 12, 2008 | 10:23 PM
  #38
tephra's Avatar
Old Nov 14, 2008 | 10:15 AM
  #39
boosted200ser's Avatar
Originally Posted by eclipzed
Please forgive my ignorance. I think Lean spool is disabled on my now 015 teprha 5.10 patched ROM, when I had 008 I had no problems at all. Now that I switched over to 015 my MPG sucks and my wideband maxes out at 10.0 when i give it slight gas to maintain speed. I am assuming that is caused by disabling Lean Spool, if it is how do I put it back to "normal" or do I need to re-tune my whole car???
You made the mistake I made. Check your maps again when you select all the top load % doesnt change. You have to click on the % line and change that as well.
Old Nov 15, 2008 | 06:15 PM
  #40
eclipzed's Avatar
boosted200ser,
You sir ROCK!!!!!! I never thought of looking at the main table values!! Once I changed them to match my previous ROM values, it fixed my issue. I now have good gas mileage!! Thanks again!!! Have a !!!
Old Nov 15, 2008 | 06:16 PM
  #41
tephra's Avatar
what u talking about? which table?
Old Nov 15, 2008 | 06:55 PM
  #42
chmodlf's Avatar
Is lean spool gear dependent? Does anyone know the lean spool algorithm?
Old Nov 15, 2008 | 11:57 PM
  #43
mrfred's Avatar
I just checked, and its not gear dependent.
Old Nov 16, 2008 | 04:26 AM
  #44
chmodlf's Avatar
What does the lean spool code do other than to check what the rpm start and stop numbers are? Does it take into account temp, knock count, load value, etc?
Does is just add 1 to the fuel value?
Old Nov 16, 2008 | 07:45 AM
  #45
todd6027's Avatar
log it with lean spool enabled then disabled then you will see exactly
