Ignition Retard Limit
Old Oct 4, 2009 | 03:59 AM
  #61
merlin.oz's Avatar
Thats nice Ceddy, looks the goods to me, well done.
Old Oct 7, 2009 | 01:07 PM
  #62
pug206's Avatar
My EvoIX Edm to -20 degrees
http://www.youtube.com/watch?v=wuy6c...embedded#at=29
Old Oct 7, 2009 | 02:22 PM
  #63
Ceddy's Avatar
Originally Posted by pug206
Pug did you use the Scaling I posted in message #60?
And did you change only one address?
88590015 is 133E, stock value 00CB
Not sure if address is universal or different in other ROMs.
Have you tried lower then -20?
The maximum possible retard should be -27, but not sure if there are additional checks that would limit it before that.
Sorry for so many questions, I don't have an Evo to test on.
Thanks.
Old Oct 7, 2009 | 02:25 PM
  #64
cossie1's Avatar
Using 235 as the retard limit on an EDM IX i've logged -22° before, however it was only for a second or so, before it changed and held -18°
Old Oct 7, 2009 | 03:17 PM
  #65
pug206's Avatar
I have not tried to lose timming -20 in the map, I'll try another day ...
My ecu took 88840617 ALS (88840013 stock) max retard 1 and 2 = 233
The explosions are very strong!
Old Oct 13, 2009 | 05:21 AM
  #66
Biggy VIII's Avatar
did anybody try to change 0x2438 (uint16) and get any success?
96530706
Old Oct 13, 2009 | 09:00 AM
  #67
JohnBradley's Avatar
hmmm interesting
Old Oct 14, 2009 | 04:24 AM
  #68
rolly1818's Avatar
Registered User
any luck with this on 88570008?
if someone guides me in the correct direction i can figure it out .... hopefully!
Old Oct 15, 2009 | 07:03 AM
  #69
Oettinger's Avatar
96530706
Bump!
Old Oct 20, 2009 | 03:13 PM
  #70
bnice01's Avatar
good info
stock ecu has came ALONG way
Old Oct 24, 2009 | 02:50 PM
  #71
todd6027's Avatar
90550001 timing retard limit to 255 or -29 gives -10 deg logged no lower
Old Oct 25, 2009 | 12:12 AM
  #72
Appauldd's Avatar
So are we going to get a table to be able to make this adjustment? If we get a table, I am willing to test the heck out of it. I am not keen on going into the MUT to make change.
Old Dec 13, 2009 | 12:46 AM
  #73
evodziobak's Avatar
hey guys. is there a table for setting that limit? I'm on 94170015 on tephra 5.10 and I can't find it. Do I neet to update to v6 or v7??
Old Dec 17, 2009 | 07:40 AM
  #74
mrfred's Avatar
I've been sniffing around the subroutine that sets the ignition retard limit, and it appears that in the newer ROMs, there are two ignition retard limit tables that are used for two different operating conditions. Not sure yet on what conditions these are, but here are the two tables for the 8859XX15 and the 9653XX06. They may both need to be set more neg for ignition to retard further under all conditions. Note that the max possible neg value is about -28 deg. Should be easy for people running newer JDM, EDM, and ADM ROMs to find the additional table by comparing the offset between the two addresses.
8859XX15:
<scaling name="IgnTimingECUa" units="deg" toexpr="61-x*90/256" frexpr="(61-x)*256/90" format="%.1f" min="-30" max="50" inc="1" storagetype="uint16" endian="big"/>
<table name="Ignition Retard Limit #1" category="Timing" address="205e" type="1D" level="1" scaling="IgnTimingECUa"/>
<table name="Ignition Retard Limit #2" category="Timing" address="133e" type="1D" level="1" scaling="IgnTimingECUa"/>
9653XX06:
<table name="Ignition Retard Limit #1" category="Timing" address="2438" type="1D" level="1" scaling="IgnTimingECUa"/>
<table name="Ignition Retard Limit #2" category="Timing" address="173e" type="1D" level="1" scaling="IgnTimingECUa"/>
88570008-88570014, 88580013-88580015, 88840016, 88900006
<table name="Ignition Retard Limit #1" category="Timing" address="2038" type="1D" level="1" scaling="IgnTimingECUa"/>
9417XXXX has only one ignition retard limit table:
Old Dec 17, 2009 | 08:15 AM
  #75
rolly1818's Avatar
Registered User
great work mrfred....
now anyone can help me find it for 8857?
