disable P0300 test
Old Nov 7, 2008 | 08:45 PM
  #91
P-ROY's Avatar
200 Miles And No Problems
Old Nov 7, 2008 | 11:50 PM
  #92
Evoryder's Avatar
Originally Posted by Brembo350z
So has your car stopped hiccuping?
No more hiccups
Old Nov 9, 2008 | 09:19 AM
  #93
boosted200ser's Avatar
My stumble is gone around 150 miles so far. The thing I notice now is it seems to go rich like 10.5 or so when it used to stumble. Wish I could log with my 2.0. I think I am going to disable lean spool.
Old Nov 9, 2008 | 03:20 PM
  #94
joedr's Avatar
EvoM Moderator
Working here! No code in 300 miles (enough to be triggered a couple of times).
Old Nov 10, 2008 | 08:17 PM
  #95
mt057's Avatar
i had to add (FCA) with the parenthesis inside the quotes after the ECUperiphery2 to make it work. thank you for figureing out this fix i almost bought a standalone to elminate the problem.
Old Nov 11, 2008 | 10:24 AM
  #96
evovette's Avatar
Worked for me as well. Im at 800 miles and no code. Also on the bright side is that the P0300 test showed up as supported and complete for my emissions test. Thats the best part of all in my opinion.
Old Nov 11, 2008 | 10:28 AM
  #97
Mellon Racing's Avatar
I don't have emissions here but that's great news
Old Nov 11, 2008 | 02:39 PM
  #98
Rob_GPT's Avatar
You guys ROCK! I just drove my 2.3 (Otherwise stock) down the road for the first time and got a p0300. Obviously i'm goign to troubleshoot for a bit but this is still great news!
Old Nov 17, 2008 | 04:18 PM
  #99
FX11's Avatar
im going in for inspection tomorow, ill let u guys know what happens. (New York)
I disabled both EGR code and 0300 code.
thank you mr fred
Old Nov 18, 2008 | 04:39 PM
  #100
Ted B's Avatar
Originally Posted by JohnBradley
I had been testing 0x8201 and 0x0001 for this but hadnt any confirmed success or failure. Good to see you had it well in hand man
I presently have "0001" in that location as per Lucas' suggestion. I believe it disables several emissions related subroutines as per my recollection. Is this correct?
Old Nov 19, 2008 | 08:15 AM
  #101
JohnBradley's Avatar
Ted,
Yes it is. The fuel pressure overun code (P0090), Evap codes, EGR codes, and a few other pesky ones. I will post the whole list up later or PM it to you.
Aaron
Old Nov 19, 2008 | 09:34 AM
  #102
Colt4g63's Avatar
Is there a step by step how to on this? Getting into the ECU and changing things like this sends my brain in to retardation mode with the computer code etc... I have Jun 272s and on cold starts I have been getting this code alot since it got colder here. The colder it is the more my car hates life trying to warm up with these cams. And it results in a P0300 code
Old Nov 20, 2008 | 12:31 PM
  #103
GotWheelHop's Avatar
Changing the periphery bit 2 to EDCF disabled my egr test as well. The car just passed an obd2 smog check with it disabled. Just an fyi.
Old Nov 20, 2008 | 11:44 PM
  #104
monkeyevo's Avatar
finally ,i threw my p0300 . it 'doesn't come back and work fine thanks a lot
you are the man !!
Old Nov 22, 2008 | 02:29 PM
  #105
Colt4g63's Avatar
Can one of you ECU gurus help me get rid of this code?? The check engine in my face and having to reset it daily is getting old
